Old 10-20-2004, 03:47 PM
jeremy2201 jeremy2201 is offline
Question blower direction control
i have a 93 grand am se 2.3 with 170,000 miles. i cannot get the air to blow out of the correct areas on the ac. it seems to want to stay in the middle blowing in my face even when i put it on another setting. sometimes it will go to where i have it set and then it will come back down. the ac compressor is not plugged up. i was told i have a vacum leak. is this true? its really annoying when i want the heat on the windshield or my feet and it in my face.
Old 11-12-2004, 08:02 PM
mrelmo mrelmo is offline
there is a small vacumn hose behind the drivers side headlight that gets schaffed and leaks move the battery to find it and splice it with a piece of washer hose
Old 11-13-2004, 10:41 AM
minister41's Avatar
minister41 minister41 is offline
Re: blower direction control
I have the same problem with a 1999. Any suggestions on this?
Old 11-14-2004, 02:02 PM
vent selection
after i tore my dash panel apart looking for a vacumn leak, a mechanic at the dealer told me to look for the leak behind the headlight on the drivers side i had to move the battery to get at it the vacumn line it rubs against the metal until there is a hole you can tape it but cut 1" out and join it with a small piece of hose from your parts store (very easy fix)
