Old 10-20-2004, 03:00 PM
PeterK PeterK is offline
01 rear hatch will not open with remote
The rear hatch on a 01 Grand Caravan will not open with the remote. Once the button is pressed, you can hear the gears trying to unlock it, but it will not open. It will work with the key though. Any ideas?
Thanks
Old 10-22-2004, 10:38 PM
dobaas dobaas is offline
Re: 01 rear hatch will not open with remote
I have the same problem with my 01 T&C, it used to work fine with the remote, now, it does the same thing, it beeps and tries to unlock and that's it. Hopefully, someone has had a similar problem and can relate to it.
Thanks
Old 10-24-2004, 10:05 AM
draasch draasch is offline
Send a message via AIM to draasch Send a message via Yahoo to draasch
open the hatch and then use a screwdriver to reset the latch so that it will be latched in the open position.....then try you remote to see if it pops the latch.....if it does, it might be binding when the hatch is closed......your the motor could be bad.....
