Old 10-20-2004, 01:36 PM
joopa joopa is offline
Unhappy Where's the !*$ Vacuum Leak
I need help in identifying a vacuum leak. I can hear it but I am not able to identify which line it is coming from. I tried to bend and pull all lines to see if there was a difference, but didn't hear any.
I heard you can use oil on a Harley, but I am afraid, 'cause where does the stuff get sucked into?
Any suggestions?
I got the leak having the car loaded with lugage and parents, hit a pot hole and my Battery light came on at the next Stop light. Idle totally low, performance crappy and milage cut in half.
Thanks,
Joopa
_______________
'91 Civic DX, $600 in 2002, $500 repairs 38 mpg! 171K miles
Old 10-20-2004, 02:27 PM
forcefanajd's Avatar
forcefanajd forcefanajd is offline
Banned
Send a message via AIM to forcefanajd
Re: Where's the !*$ Vacuum Leak
Any suggestions?
Thanks,
Joopa
_______________
the easiest wayt o find a vaccum leak is to get a can of carb cleaner or starting fluid andspray your vaccum lines....if the idel goes up or you hear a change in the idel when your spraying a certain part your vaccum leak is in that area.
