Old 10-20-2004, 12:58 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Question Mill the head?
Ok I am putting together a fresh built Y8. I am going to have the head plained to make sure it's flat. I was thinking of milling it to bump up c/r. How much do I need to have it milled to tell a difference? Also this won't effect the head bolt tightness would it?
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 10-20-2004, 01:33 PM
91civicDXdude's Avatar
Re: Mill the head?
it will affect cam timing. I would suggest just milling it flat. If you want higher compression (high enough to make a difference) then get high compression pistons. milling the head in conjunction with a thinner head gasket *might* bump up your compression .2
Old 10-20-2004, 05:03 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Mill the head?
ya i heard milling a bad thing
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 10-20-2004, 05:17 PM
Re: Mill the head?
I have 10.5:1 SRP's just wanted a little higher bump. What kind of head gasket will help the c/r on a Y8?
Old 10-20-2004, 10:30 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Re: Mill the head?
Well the y8 already has the thinnest head gasket, Maybe I suggest getting a new y8 head gasket and removing a layer of the gasket, It will bump it up a little. Or try to find an aftermarket head gasket that is thinner.
..Or get the head milled/resurfaced.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
