Old 10-20-2004, 12:01 PM
zangore zangore is offline
Send a message via AIM to zangore
2001 3.4 V6 racing mods???
does any one know where I can get a turbo, or a chip replacement kit so my governer and stuff is changed?
Derrick
Old 10-30-2004, 04:05 AM
puppyboi puppyboi is offline
Wink mods!
i talked to my car dealer and he said for about $1,200 i could get the upgrade set-up with computer. he did not tell me where tho!...i will look into this more for you...what state do u happen to live in?...just to help me further my search!
thank you all!
u r special
from,
the pup
Old 10-30-2004, 05:49 PM
jamcllw jamcllw is offline
Re: 2001 3.4 V6 racing mods???
HOLY CHRIST!!! $1200 for a computer upgrade? You can get the DHP computer for less than $300. And yes it does remove the speed governer. But just remember you hit your breaks going over 108 MPH they are very likely to melt and not do anything for you. Removing the speed limiter is one of the dumbest things you can do to a stock car. They aren't built to go that fast. The tires aren't rated at those high speeds and the brakes are pretty much going to be worthless. And since I don;t know which motor you have I'm going to say turbochargedpower.com for the 3400 V6. It's for a Grand Am but they are practically the same car. And for the 4 bangers check the j-body forums. Just about everything that will go onto a j-body will fit the 4 cylinder aleros.
Old 10-30-2004, 11:27 PM
$1200 for computer upgrade, onboard computer, intake and fuel injection.
u r special
from,
the pup
Old 11-02-2004, 02:15 AM
yeah my car is stock for the most part, but i do have yokohama type z-racing tires, and I do have new raing brakes in the mail. Also, cold air intake. I live in South Texas, thx for all the help.
Derrick
Old 11-02-2004, 02:16 AM
o and ive used my brakes past 108 and they were fine.... ive used them at 115.
Derrick
Old 11-02-2004, 02:17 AM
motor is a 3.4L V6
Derrick
Old 11-02-2004, 02:25 AM
and what is a DHP computer??? and where can i find one.....
Derrick
Old 11-03-2004, 07:20 PM
http://www.digitalhorsepowerinc.com/products.htm
Old 11-04-2004, 12:09 PM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
The brakes will work past 108... They will also fade really fast! Your looking at a minimum of better pads rotors braded steel lines and fluid! A better tire than stock is a must! If you really want to go that much faster than I would recomend suspension upgrades as well. The alero and grandams seem to have alot of oversteer in them at faster speeds and alot of understeer at slow speeds! The first time you drift the tail out at 70-80 youll know excatly what i mean. The suspension on these cars are not well thought out at all!
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
Old 12-13-2004, 03:34 PM
02oldsalero 02oldsalero is offline
Re: Re: 2001 3.4 V6 racing mods???
Do you mean upgraded fuel injectors or just fuel curve upgrade?
thanks
Old 12-13-2004, 03:38 PM
upgraded fuel injection
with an upgraded intake manifold
u r special
from,
the pup
Old 12-19-2004, 03:46 PM
Kouga's Avatar
Kouga Kouga is offline
Send a message via ICQ to Kouga
the brakes work well up to 125 mph - im driving once a week @this speed from south germany to northern where my parents live. i do not know if they are the same like in the us. i will post a pic if anyone wants to.
but they are shaking alerolike... its a lil fearsome sometimes but you get used to it...
Old 03-30-2005, 01:02 AM
vamc's Avatar
vamc vamc is offline
Originally Posted by jamcllw
Please tell me how that chip will work if you have a programable cpm? It will not accept chips. there are no chips for the alero. jet chip said no and if the digital chip does work, once you bring in your car for repairs, it will delete the chip once they put their computer up to it.
Old 03-30-2005, 08:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Re: 2001 3.4 V6 racing mods???
There is no chip upgrade by itself from those companies. However, companies such as ASE will re-program your stock ECU after you send it in to them. We had it done to our '02 Alero GL2 after the bumper to bumper warranty expired.
If you take the car in for service, it is quite possible for a tech running a GM Tech 1 or Tech II machine to delete or overwrite the contents, etc. However, running a simple OBD-II scan with a scanner/code reader will not delete or overwrite the memory of the EEPROM.
The way around this is to get a complete stock ECU/ECM from a similar Alero model and year as a backup. We got one for $200 at a salvage yard and keep it for a spare, just in case.
This mod makes a big difference considering the cost.
