Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-20-2004, 09:27 AM
millseynz millseynz is offline
Adjust my 4runners idle
Just bought a 1985 4Runner, and the truck idles very high. No problems once I'm in gear, but while stationary the ebgine revs very high, any suggestions on what I should do?
Old 10-20-2004, 10:31 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Adjust my 4runners idle
What engine? Carburetor or FI?
Old 10-20-2004, 01:10 PM
4Runner
Thanks Brian, it is a 1985 body with a 1986 engine FI, 5 speed.
Old 10-20-2004, 01:58 PM
Brian R.'s Avatar
Resident Chemist
Try cleaning the throttle body:
http://www.4x4wire.com/toyota/mainte...throttle_body/
Old 10-20-2004, 02:03 PM
Thanks Brian for the link. Not sure what the throttle is, though I didn't know what a rear diff was either until I changed mine out yeaterday..this 4runner will be a learning curve
Old 10-20-2004, 02:30 PM
Brian R.'s Avatar
Resident Chemist
Use a sensor-safe cleaner
Old 11-26-2004, 05:46 AM
forest_grump forest_grump is offline
Check for vacum leaks and brake booster leaking by *pinching* shut the rubber hose going to brake booster with needle nose pliars(same can be done to other vacum lines as long as careful not to colapse metal lines they conect to if present.
