Old 10-20-2004, 07:06 AM
Mannheim 80 Mannheim 80 is offline
Red face Wednesday Humor
Complaints Submitted by USAF Pilots
Here are some actual maintenance complaints submitted by US Air Force pilots and the replies from the maintenance crews. "Squawks" are problem listings that pilots generally leave for maintenance crews.
Problem: "Left inside main tire almost needs replacement."
Solution: "Almost replaced left inside main tire."
Problem: "Test flight OK, except autoland very rough."
Solution: "Autoland not installed on this aircraft."
Problem #1: "#2 Propeller seeping prop fluid."
Solution #1: "#2 Propeller seepage normal."
Problem #2: "#1, #3, and #4 propellers lack normal seepage."
Problem: "The autopilot doesn't."
Signed off: "IT DOES NOW."
Problem: "Something loose in cockpit."
Solution: "Something tightened in cockpit."
Problem: "Evidence of hydraulic leak on right main landing gear."
Solution: "Evidence removed."
Problem: "DME volume unbelievably loud."
Solution: "Volume set to more believable level."
Problem: "Dead bugs on windshield."
Solution: "Live bugs on order."
Problem: "Autopilot in altitude hold mode produces a 200 fpm descent."
Solution: "Cannot reproduce problem on ground."
Problem: "IFF inoperative."
Solution: "IFF inoperative in OFF mode."
Problem: "Friction locks cause throttle levers to stick."
Solution: "That's what they're there for."
Problem: "Number three engine missing."
Solution: "Engine found on right wing after brief search."
Old 10-20-2004, 09:43 AM
Damien's Avatar
Damien Damien is offline
Send a message via AIM to Damien Send a message via MSN to Damien
Re: Wednesday Humor
*lol*
Sounds like occurances that would really happen
Old 10-20-2004, 10:37 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I loved it the first time around too http://www.automotiveforums.com/vbulletin/showthread.php?t=221259&highlight=Evidence+removed
and add these from that list
P: Suspected crack in windshield.
S: Suspect you're right.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
Resistance Is Futile (If < 1ohm)
Old 10-20-2004, 12:27 PM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Re: Wednesday Humor
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 10-20-2004, 12:28 PM
LotusDreams LotusDreams is offline
Re: Wednesday Humor
"Problem #1: "#2 Propeller seeping prop fluid."
I laughed so damn hard at that haha.
Old 10-20-2004, 12:49 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: Wednesday Humor
I've seen pages and pages of humor like this on some website that I found a while ago...
Unfortunately, I didn't bookmark it, so I don't remember the site....
