Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-20-2004, 03:25 AM
mkvapil mkvapil is offline
10 disc CD changer "ERR"
I have a 10 disc CD changer and it would say "ERR" on the radio dash quite often. I just have to keep trying until it picks up a cd and play. What is causing the changer to display "ERR"? thanks
Old 10-20-2004, 11:24 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 10 disc CD changer "ERR"
are u trying to play a burnt CD?
Old 10-20-2004, 12:21 PM
Myrtle Beach Myrtle Beach is offline
Mine started doing that all the time. I couldn't even listen to CD's until I had it replaced. It worked for 2 years and then started doing the same thing again. i got so frusterated with it that I bought a pioneer head unit and am looking to get a 10 disc pioneer changer later this year. If you find a way to fix it let me know. (i think they are just cheaply made changers though)
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Old 10-20-2004, 01:22 PM
the Infinity Deck in my jeep had trouble playing burnt CD. so I decided to replaceit with a Pioneer (The best).
Old 10-20-2004, 02:15 PM
Some cds are burnt and some are not. Won't play both kind. I just have to keep changing cd until it finally plays.
Old 10-20-2004, 02:34 PM
have u tried to run a lens cleaner and c if that helps?
Old 10-20-2004, 02:37 PM
Godzilla.vs.Jeep's Avatar
Godzilla.vs.Jeep Godzilla.vs.Jeep is offline
Kinda off the topic, but where are the 10 disc units mounted in the vehicle??
Old 10-20-2004, 02:41 PM
yea ic, maybe heat is causing the problem. it needs air, so if it is in a tight copt where it doesn't get much cool air then that might be causing the problem
Old 10-20-2004, 02:42 PM
COPT, I don't know wtf that is, I meant spot
Old 10-20-2004, 04:40 PM
The cd changer is mounted in the rear cargo area on the right side panel.
Old 10-20-2004, 04:42 PM
You can hear it making clicking noise like its trying to get the cd popped in but couldn't.
Old 10-20-2004, 04:45 PM
does the CD Changer sit on it's side or vertical.
Old 10-21-2004, 03:53 AM
Vertical, the cartrudge pops out at top.
Old 10-21-2004, 11:16 AM
OK, put it on it's side, sometimes they have problems reading disc verticall b/c the lil tabs that hold the disc in place are fitted too loosely, and the low quality CD player can't read the disc if it flops aroudn a lil. I had this same problem with the PS2 when it is vertical.
so try to put it on it's side and c if that helps, let us all know if it works.
Old 10-22-2004, 03:40 PM
I think i got it working now. Not keeping my hope up yet. I used 3in1 household oil inside the slot. I can see that the grease, might be white grease, is all dried up. I greased all the bearing, acutator, and anything thingmingjing that possibly need to be greased. So far so good.
