Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-20-2004, 02:13 AM
gvistan gvistan is offline
2003 Chevy Tahoe Keys
My wife lost her keys about a year ago. I then bought a remote from ebay. I search on this forum and found ou how to program it. Now my question is, can I get my other original key and have a local hardware or lock smith make a copy or do I need to buy one from the dealer?
Old 10-20-2004, 07:03 PM
TGARST TGARST is offline
any good locksmith shop should be able to copy your key, i had one made for my 2003 Yukon
Tim
Old 10-25-2004, 08:15 PM
colhoeft colhoeft is offline
Re: 2003 Chevy Tahoe Keys
Can you send programming instructions? I have an 03 Tahoe with 3 remotes, yet only one works. The ID number on the back of each remote is different....does that make a difference? Thanks.
Old 10-25-2004, 09:26 PM
Qbertsaok Qbertsaok is offline
Hi,
Hope this helps....
1- Close all the vehicle doors.
2- Insert the key into the ignition cylinder (do not turn on).
3- Press and hold the door unlock switch on door panel.
4- While holding the door lock switch in the unlock position, cycle
the ignition ON, OFF, ON, OFF.
5- Release the door unlock switch. The doors will lock and unlock
to confirm the program mode.
6- Press and hold the LOCK and UNLOCK button simultaneously on one
transmitter. After a delay of approx. 15 seconds, the doors will
lock and unlock to confirm the programming of that transmitter.
7- Repeat the previous step to program up to 4 transmitters.
8- Turn the ignition switch to the RUN position in order to exit
the keyless entry transmitter program mode.
9- Operate the transmitter(s) functions to verify proper operation.
Old 10-27-2004, 10:12 AM
Thanks for the info. I tried the process several times but it stops at item 5 (doors do not lock/unlock to confirm programming). Am I doing something wrong. Your instructions were very clear and precise, so there must be some other thing I'm missing. The 2 remotes I am trying to program have different FCC ID numbers.....could that be the problem?
Old 10-27-2004, 06:20 PM
Yea, I think they have to be the same, because they have two different signals (codes) they transmit when you push the buttons...Try programming only one transmitter, if you havent already.
Old 10-30-2004, 11:19 AM
You're absolutely correct. There is a specific GM ID code for each type of vehicle. The other two fobs I was given were for S10 pickups. They were given to me by the dealership where we bought our Tahoe. Go figure.
Old 12-08-2005, 07:50 PM
eriojas eriojas is offline
2002 suburban, did everything here, when pressing unlock and lock on the remote, after 15 seconds doors lock and unlock, turn the ignition to run, and the remote doesnt work, missing anything, its the original remote, one day it just stopped working and changed the battery
Old 12-09-2005, 10:36 AM
Re: Re: 2003 Chevy Tahoe Keys
The remote fobs must have the correct ID number on back, which I presume is OK since it is the original remote. Below is the sequence I used and it worked fine, but it did take about 10 times before it finally worked. In fact, I went to the dealership when I could not get it to reprogram initially, and they tjold me it required a computer and took about an hour with a charge of $70! (liars!) I declined their generous offer and went home a tried until it worked. I think I did disconnected and reconnected the battery to the car which restarted the entire computer system to the factory default. I don't know if this actually helped, but I was able to reprogram the remotes after doing so. I would recommend NOT disconnecting the battery and trying several times using the below sequence. Good luck, have a great Christmas! Bill
Hi,
Hope this helps....
Report
Old 12-09-2005, 01:14 PM
thanks Bill, any difference in the ON and RUN position, at the end it says put it on the RUN position
Old 12-09-2005, 11:59 PM
Yes, the RUN position is the key position as far as it will go without actually activating the starting motor. It's just before you hit the starter.
Old 12-14-2005, 11:57 AM
Re: Re: Re: 2003 Chevy Tahoe Keys
did it and the remote just doesnt work after doing everything, it opens and locks after the 15 seconds with the remote buttons pressed afeter that it just doent do anything, weird,, guess ill have to go to the dealer.... thnkas for your help and marry xmas
