Old 10-19-2004, 11:11 PM
Josh95cx Josh95cx is offline
Prelude injectors
I was wondering if you could use 90-91 LS injectors or the older prelude with the b20a injectors with a 89 SI civic ecu. I have both of these and no A6 injectors, So i was wondering if they would work.
Old 10-19-2004, 11:58 PM
91civicDXdude's Avatar
Re: Prelude injectors
yes you can use them. they're all the same size fyi
Old 10-20-2004, 12:41 AM
Is there anyway to use a Z6 Dizzy with a pm6?
Old 10-20-2004, 10:19 AM
no. they are not compatible.
Old 10-20-2004, 12:40 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
do 1.8l injectors spray more fuel or are they all the same spray rating??
Old 10-20-2004, 01:31 PM
240cc. the difference lies in base fuel pressure and fuel injector pulsewidth in fuel tables
Old 10-20-2004, 01:43 PM
travagliante's Avatar
travagliante travagliante is offline
What has it been lately with people thinking bigger injectors = more power????
Old 10-20-2004, 02:28 PM
Re: Re: Prelude injectors
and also that prelude/integra/b16 injectors = bigger :P
Old 10-20-2004, 04:07 PM
kris's Avatar
kris kris is offline
Off playing with fire.
There are also difference, like peak and hold, saturated, etc.
Also, 92 and up preludes are 345cc, peak and holds.
Old 10-20-2004, 04:21 PM
1PhatCX's Avatar
i just need more fuel to be sprayed in during WOT, because of the bored throttle body its getting alot more air coming in. and not enough fuel to supply it, so i think thats why i get that bog/hesitation when i put it right to the floor. i wanna find some kind of injector that will supply the needed fuel for me without me running rich. i dont think that bigger injectors means more power... the way i see it is too much air with small injectors means lean... and more fuel and run ideal or rich depending on how much more fuel u add.... aslo fuel economy goes down the crapper with larger injectors usually
Old 10-21-2004, 01:15 PM
kris's Avatar
Just because you have a large TB, doesnt mean it will benefit you. It's like trying to fit 10 gallons of water, into a 5 gallon bucket. Your manifold, and intake ports are still the same size.
