Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-19-2004, 11:02 PM
lwrdcav lwrdcav is offline
cv joint
Can anyone tell me where the cv joint is? Also, how would i go about replacing them. I am also replacing my front wheel beaings; should i change out the hub at the same time. i heard this lengthens the life of the bearings.
Old 10-20-2004, 01:51 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: cv joint
the CV joints connect the hubs to the transmission(right side also uses a intermedite shaft)
mine broke earlier this year:
http://www.saturnfans.com/forums/sho...threadid=32086
how-to is haft way down by wolfman
http://www.saturnfans.com/forums/sho...hreadid=32019&
i also had to loosen the sway bar, and a jack under the hub helped for position. changing the hubs and wheel studs is not a bad idea if you are doing the bearing and CVs with it. i bought a new CV joint for 110 at autozone, pretty good price, i would buy new not remanufactiored.
