Old 10-19-2004, 09:42 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Question Alternator whistling???
my alternator in my crx is kinda making a whistle/air blowing noise,
and when that nosie started, 30 sec. or so after i start my car my rpms drop and my car feels like its gona to die out untill i give it a little gas its back to normal or untill i shut off the car. has anyone experienced this?
Old 10-19-2004, 09:49 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Alternator whistling???
do you have a big stereo in your car?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-19-2004, 09:55 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Has it been a long time since you started the car?
Old 10-19-2004, 10:04 PM
jhmcrx's Avatar
its been doing this for abouuuut almost 2 weeks
Old 10-19-2004, 10:05 PM
jhmcrx's Avatar
but come to think of it there WAS a big system before i got the car
Old 10-19-2004, 10:09 PM
johnb16a2's Avatar
Loose belt?
Old 10-19-2004, 10:19 PM
jhmcrx's Avatar
i dont think so, my alt. and my cam gear are very close and the noise is coming from there, the only belt areound there is my timing....that can't cause my problem can it?
Old 10-20-2004, 07:38 AM
CR50HC CR50HC is offline
This is what I did. I took the extension tube from a Shop Vac Vacuum cleaner. I put it up to my right ear and then systematically moved the open end of the tube to different spinning and moving parts of the engine bay. Once I reached the offending sound producer you could hear it louder than anything else in the engine bay. It turned out to be a bad alternator in my case. This method is cheap and effective and safe so long as you don't have long hair, a long chain, a tie, or loose clothing that could catch onto something moving. if it's not your aternator, it could be a belt tensioner, or pully bearing.
Troy
