Old 10-19-2004, 10:21 PM
GSTRacerNVUS GSTRacerNVUS is offline
Eclipse Recall Dec 2000
Ok, well... I'd have to say that I'm already pissed off, cause I was supposed to have my whole front axle rebuilt with new parts (cheaper than replacing). Any way... I knew that I had a bad rubber boot on one of the lower lateral arm ball joints. I expected this to be fixed when I took it to this guy to do (never have or will go back to him again... Its been a few months). So I get a flat tire and my friend put the spare on for me (good thing to have a guy help out... Sometimes I don't want to get dirty... Sometimes I do.) And ofcourse he has to say "Hey! You know you have a bad boot on your axle." To me, this is just one more thing to add onto the list of things to fix that should have been fixed list. At this point, I'm pretty accepting of New things going wrong; however, I felt pretty stupid trusting this guy to do a rebuild and do a complete one (if he did anything at all) on my axle. So, to the point. I was going through the recall list for 97 Eclipse models and found one on Dec 15, 2000 for possible damage to the rubber boots during assembly, which can bring in water and dirt. In addition, the boots also could possibly leak moisture which can cause the ball stud to corrode. Has anyone else had this problem? If so, can you still have it fixed after the recall expires?
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 10-19-2004, 10:40 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Eclipse Recall Dec 2000
To my knowledge, recalls never expire. Normally they are "safety recalls", which means you could have a REALLY bad day if the part/parts being recalled broke. As for the lower ball joints, I had them replaced in February on my Spyder. Just call the dealer and give them your VIN and they will be able to tell you if the recall has been done on your car. Good Luck!!!!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-20-2004, 01:48 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
that's a very old recall. take it to the dealer and have them replace it. it'll take them 20 mins with no cost.
LMAO!!!... that sig of your spyder... LOL.. taht is so wrong!!!
06 Charger SRT-8 black.
Old 10-20-2004, 02:08 PM
Harder Faster's Avatar
Harder Faster Harder Faster is offline
I just recently got the lower ball joint safety recall done on my car.
Good thing I did because my tires were about ready to fall off.
It took them about 1/2 hour, but when I drove home, my alignment was way off.
Aren't they suppose to do an alignment too?
Anyways, my car floats side to side now when i'm driving on the freeway. I'm thinking that I need to re-do the whole suspension, but the guy at the dealership never mentioned anything about worn parts that needed to be replaced.
Old 10-20-2004, 03:48 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Is the recall for a specific model and year?
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 10-20-2004, 06:39 PM
can't remember... threw out the letter ages ago. call the local dealer ducky. they'll find out if you have any outstanding recal.
Old 10-21-2004, 02:41 AM
I think all '97 Eclipses lower lateral ball joints were recalled.
Go here to find out if there's a recall for your ride....
http://www.alldata.com/recalls/index.html
Old 10-21-2004, 03:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
95s too, mine have been changed 2-3 times.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-21-2004, 11:27 AM
Re: Re: Eclipse Recall Dec 2000
How many times are they gonna do it till they get it right?
97 Eclipse GST MT
Old 10-21-2004, 11:43 AM
AF - Advisor
Piss poor design on the part itself. They change the recall a couple times. The first recall was to slap some goo on the bad boots Too late to change the design though. I think the latest version is just better boots. Same part otherwise though.
BTW, anyone can inspect thier own balljoints, and I would seriously recomend everyone go take a look. Some poeple dont find out they're bad until the tire is facing in the wrong direction, and things get ugly.
JAck up the front of the car. The balljoint in question is on the "Lower Lateral Link," the straight arm coming out from the front "K member" to the knuckle. Use a prybar or a helper or something to lift the tire not far (1/2" will do), but abruptly. On a lift, use your shoulder to jerk the wheel upward. If the knuckle goes up without that arm a noticeable amount, the joint has failed. Spec limit is around a 10th of a mm, IIRC, but its been a while so that could be off a bit.
Kevin Jewer
Old 10-21-2004, 09:01 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
yeah i had my lower lateral balljoints replaced for free also.
Old 10-21-2004, 09:42 PM
damn that cat looks evil !
Old 10-22-2004, 01:57 AM
AF - Advisor
Looks a bit like my cat. All black anyway... One eye is smaller than the other, freaks me out sometimes.
Kevin Jewer
Old 10-22-2004, 08:59 AM
She is. She's got the split personality disorder. She comes up all nice, you pet her, she purrs, then she tries to take your hand off. Only to people she doesn't know though.
97 Eclipse GST MT
