Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-19-2004, 08:55 PM
Dannk Dannk is offline
Random Cylinder Misfire...
My truck has been periodically missing out - but then seemed to go away. I kept driving it waiting for a Check Engine light to help my diagnostics. Well it came on today with a P0300 (Cylinder Misfire Detected - Random) code. I recently changed plugs, wires, cap and rotor. What is next?
Old 10-19-2004, 08:56 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Random Cylinder Misfire...
What year do you have?
What plugs did you use and how much gap did you gap them too?
Did you install a new fuel filter lately?
Changed gas stations recently?
Old 10-19-2004, 09:29 PM
Fireplug Fireplug is offline
OMG not the P0300 That is a GM techs nightmare.
It could be just about anything from the change over in gas from summer to winter(if you live in that type of area) to a piece of carbon on a plug.
Did you use all AC Delco parts?? Please say you did
Do you have any of the scan tool readings or was it just a code reader??
Fireplug
Old 10-19-2004, 09:49 PM
Re: Re: Random Cylinder Misfire...
It's a 1996 S-10, 4.3W. I cannot recall what brand I used - but it was not the cheapest available. I gapped the plugs to the spec under the hood too. I have changed the fuel filter withing the last 3 months (along with the fuel pump).
I change gas stations all the time - but it's been doing this for 3-4 tanks now.
I have all the DTC info and Freeze frame data, but not with me now...
I just inspected the coil and it has some severe discoloration around the housing near the "iron bar" that wraps around it. Almost like it's been arcing to ground??? Too bad I cannot watch it while I'm driving! Could it be a bad coil?
Old 10-19-2004, 09:51 PM
I thought P0440 (EVAP system) was a GM tech's nightmare!!!
Old 10-19-2004, 11:59 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Random Cylinder Misfire...
Aha! This is have heard of before!
Yes, it is probably your beast! Replace the coil and try that out.
The arcing can definitely be the problem.
Old 10-20-2004, 08:03 AM
Jeremy-WI Jeremy-WI is offline
I would try a new distributor cap with brass contacts
Old 10-20-2004, 08:21 AM
A very easy test is to take a small spray bottle with water in it and MIST the entire system while looking for any arcs. Also look at the ing wires and see if there are any white patches spots on the wires . That is a tale tale sign that they are arcing to ground.
Fireplug
Old 10-20-2004, 08:54 AM
Dannk
yep
po440 and put that stupid evap machine and do all the stupid tests and then get paid .3 time for and hours work and then find a loose gas cap.
I just lived for a evap code.
Fireplug
Old 10-20-2004, 11:35 AM
BlazerLT's Avatar
AF -Advisor
From past reading, most people with this problaem have the arcing coil pack.
Best to look at it at night with no lights on and look for the blue light from the arcing.
Old 10-20-2004, 12:27 PM
Good point.
I found what works nice is to take a mixture of washer fluid and water and mist it on .Then I day The mixture was too much washer fluid and it flashed (can we yell FIRE) It did no damage to the car because it was just a little puff. I did find the problem and had to change my shorts after I was done.
Old 10-22-2004, 10:29 AM
I replaced the Coil Pack and it seemed to fix the problem. $32.50 aint bad! It actually runs a lot better now too! It was not real easy, but I probably saved $100-$250 by doing it myself. You have to remove a bracket to remove a bracket to remove a bracket the coil is fastened to. Thanks GM for designing POP RIVETS into the coil pack bracket assembly....freekin interns.
Old 10-22-2004, 12:27 PM
BlazerLT's Avatar
AF -Advisor
Good to see you got it fixed.
Old 11-22-2004, 02:43 PM
Well, I was wrong - again. A few days after my last reply, it started missing out again. I have been putting up with it but now I have to get it fixed (I need a dependable car for the winter). For review, I have replaced the following within the last 2 months:
1. spark plugs
2. cap and rotor
3. plug wires
4. coil pack
When it's real bad the Service Engine Soon light will come on with a code of cylinder misfire detected (random) P0300. It will go off on it's own. It really only misfires under normal driving conditions. When I mash down the gas it seems to run very strong. It really feels like crossfiring in the distributor BUT it's a brand new cap???
PLEASE HELP!!
Old 11-22-2004, 02:57 PM
BlazerLT's Avatar
AF -Advisor
Sounds like you should do some fuel system diagnosis.
Fuel Filter
Fuel Pressure test etc...
1995 Factory Blazer Service Manual for sale, PM if interested.
Closed Thread
