Old 10-19-2004, 08:44 PM
3000GTRip 3000GTRip is offline
Guages and pods HELP!!!
Ok i want to intall a transmission cooler,and i want a temp guage for it. and also maybe a air/fuel guage. SO the question is how do i wire for it and install it on the side on the car!! Thanks -rip
Old 10-19-2004, 11:17 PM
Hotshot8792 Hotshot8792 is offline
transmission temp gauge, you'd need to get a temperature probe welded into your transmission pan or find some other place to install a probe where it makes contact with your auto tranny fluid. Then you'd run the probe's wires up into the engine bay and through the firewall where it comes out above the brake pedal inside the car. Drop the lower part of the dash and run it up to the a-pillar where you will have your a-pillar gauge pod. Same thing with the a/f gauge, you hook the power up to a power source that turns on when the car does, a ground source, and the white wire will go to your O2 sensor wire which is by your ECU. I still say its pointless to get an A/F gauge unless you have a wideband set up for your car.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 10-20-2004, 02:09 PM
Igovert500's Avatar
blue + red light magnet
Re: Guages and pods HELP!!!
http://www.stealth316.com/2-wiring-tips.htm -light wiring
http://www.stealth316.com/2-a-pillar-cover.htm -removing a pillar
http://www.stealth316.com/2-autometer3373.htm -installing gauge in a pillar
These may help a bit
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
