Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-19-2004, 08:42 PM
imgone52 imgone52 is offline
ABS activating at low speed
Having problem with ABS on front wheels activating at low speed 5MPH
when breaking to a stop. Happens most often while turning into parking spot ect. ABS fuse pulled and the problem goes away so there is no question it's brake system. Any Ideas?
Old 10-20-2004, 08:31 AM
Jeremy-WI Jeremy-WI is offline
Re: ABS activating at low speed
A speed sensor for the ABS system is obstructed. Do a search for ABS TSB and you should find out how to correct
Old 10-21-2004, 11:47 AM
Thumbs up
Thanks for info. GMC dealer read ABS computer and did visual inspecction. Caught it early so cleanup of sensor was possible instead of hub replacement.
Old 10-23-2004, 03:23 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ah the ole Vehicle speed sensor problem.
