Old 10-19-2004, 08:21 PM
TwentyPints TwentyPints is offline
lift, or spacer, or what im lost?!
whats the cheapest and most effective way to have my 04 level, since it slants higher at the back. i want it to sit maybe a bit higher like the 2500's. mine is a 2wd, and i am running 265/16's bfg mud terrains.
Old 10-19-2004, 09:21 PM
silveradoman silveradoman is offline
Re: lift, or spacer, or what im lost?!
You might want to take one of the leaf springs off, but itīs not going to load the same amount of cargo.
Old 10-20-2004, 09:37 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
You could get a 2" spring spacer. or 2" drop shackle.
*Under Construction - New sig to debut*
Old 10-20-2004, 12:57 PM
Sivart Sivart is offline
They do offer a 1-1/4" coil spring spacer that will work just fine. I bought mine through 4 wheel parts.
This leveled our Tahoe right up.
Old 10-20-2004, 08:09 PM
will these spacers require aftermarket shocks? my truck came stock with the "heavy duty shocks" as it said on the invoice.
Old 10-21-2004, 07:48 AM
They should work but you will decrease your travel unless you change them. I used the same shocks on ou Tahoe but it is just a steet vehicle so it really does not need much travel.
Old 10-21-2004, 03:46 PM
did u install them yourself?
Old 10-22-2004, 10:45 AM
Yep I did, You will need a coil spring compressor to do it. Other than that it is not a hard job. You will need to get it aligned after you done.
Old 10-23-2004, 10:23 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Drop the rear two inches..no need for realignment or for different shocks or spring compressors. Cheapest easiest way to go and your truck will be level.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
