Old 10-19-2004, 05:51 PM
Rushlowjr Rushlowjr is offline
Ignition switch now trans codes
Okay, So I found this forum and discovered how useful it is. I am now a member of this forum in search of help...
1997 Blazer 4WD LT I had all of the classic symptoms of the dreeded ignition switch gone bad. I replaced it with the help of this forum. Now after the new switch my SES light is on and the only codes that come up are for the trans., go figure because I no longer have OD or 1st gear. I have put the old ign. switch back on and the same code comes up. Please help me. This is my work truck and my only vehicle.
Old 10-19-2004, 06:00 PM
Mikado14 Mikado14 is offline
Re: Ignition switch now trans codes
First of all, you should have left the ignition switch in the vehicle after you changed it out. Why would you remove it after installing? You should read the codes OR disconnect the battery cables for 10 minutes or longer to reset the PCM then see if you still have the codes.
Old 10-19-2004, 06:10 PM
Re: Re: Ignition switch now trans codes
I called GM service and explained what is happening. They told me right off without hesitation that it was the ign. switch. They have seen the same problem and have rebuilt a couple of trans. only to find out it was the damn switch. That is why I tried the old one again. Keep in mind I did not have any trans problems with the old one to begin with. After I put the new one in is when the trans started acting up.
Old 10-19-2004, 06:17 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Reset the computer by removing the negative and positive battery terminal while you are doing this.
Old 10-19-2004, 06:18 PM
did that already and there was no change
Old 10-19-2004, 06:22 PM
BlazerLT's Avatar
AF -Advisor
Ok, well, you need to put the new switch back in there. Having the old faulty switch still in there solves nothing.
What are the codes you are getting, we need the exact numbers.
Old 10-19-2004, 06:25 PM
I don't remember exact numbers because I am a dumb ass and just went to Auto Zone. sorry guys... I received codes regaurding selonoid a and b
Old 10-19-2004, 06:27 PM
barpat96's Avatar
barpat96 barpat96 is offline
same thing happened to me. I had 5 codes
Old 10-19-2004, 06:29 PM
I know it is something electrical. I don't think that the damn selonoids would have gone bad sitting in the garage for 4 hours. It doesn't make much sense.
Old 10-19-2004, 06:33 PM
barpat96's Avatar
Here is the codes i got P0758 solenoid B,P0753 Solenoid A, P0785 Shift timing solenoid, P0740 Torque converter clutch, P1860 Transfer case contact plate D. The autozone employee said that my tranny was bad. It turned out to be the ignition box (Black Box) I know you don't have the codes but i put this on here for reference later
Old 10-19-2004, 06:34 PM
What do you mean by ignition "box"
Old 10-19-2004, 06:37 PM
barpat96's Avatar
under the key hole there is a black box that is connected to wires. The box can not be changed without replaceing the wire hrness that is attached. Is this what u did?
Old 10-19-2004, 06:41 PM
Yes, I bought the Wells brand from AutoZone.
Old 10-19-2004, 06:46 PM
When you changed the ignition switch, on the part that has the 10mm bolt (this bolt is used to pull the connectors together and maintain a firm seat) on it, there are two plugs on either side that are a part of the entire socket, they slide down and snap in place, one is gray and one is black.
Do you have them seated all the way?
Old 10-19-2004, 06:48 PM
barpat96's Avatar
here is a picture.
http://www.smpcorp.com/mycgi/ibg.asp?parts=US295
Just wanted to make sure we are on the same page
