Old 10-19-2004, 05:49 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
over head console question
alright guys, i got me an overhead console, with the self dimming mirror at a junk yard for $45 back in the summer. i just put it in place and the only thing that works on it is the dome light. i do have the wiring harness to make it work but i just want to make sure that it will just plug into my harness in my 90 camaro and work. it came from a 88-90 iroc, the dome light should be one of those that stays on for a few seconds and then fades to off, now i know to take the dash pad out of my car and take the driver side pillar out, now if i plug the harness in for the over head console and hook it up right including the mirror, will it all work with my 90 models wiring. will the dome light dim out like it should after the door is closed
Old 10-19-2004, 08:26 PM
Dober89 Dober89 is offline
Re: over head console question
I think the standard overhead light uses the same gauge wiring as the console did. They stopped making those consoles in 87 too though and mine unplugs right above the mirror basically.
You got the pins to mount it too?? I think you should just have to tap the holes and thread them in.
Old 10-19-2004, 10:38 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
you guys wouldnt happen to have, or know where i can get a picture of the overhead console you are talking about...
*Better power-to-weight ratio than a C6 corvette*
Old 10-20-2004, 03:25 PM
ill take one for you when i go out to the garage and find it
Old 10-20-2004, 11:13 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
here's one on ebay...
http://cgi.ebay.ca/ws/eBayISAPI.dll?...spagename=WDVW
there are others too, i wasn't lookin at price just for a pic
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-21-2004, 03:01 PM
there was no drilling needed. all of the holes were there for the pins allready. it didnt take 5 minutes to install it.
Old 10-21-2004, 03:29 PM
you didnt have to tap the holes at all??
Old 10-21-2004, 03:39 PM
nope, its comes with some little I shaped locks that just slide into the slots that are already in the roof of your car, that is if you have a t top car. all t top cars from 85-92 has the slots and hols already cut out.
Old 10-21-2004, 04:54 PM
that thing looks kindof cool, i was thinking if i could get it to fit into my fourth gen, but was wondering if it would first fit and second if it was worth the effort...
Old 10-21-2004, 05:08 PM
i dont think the forth gen would have a straight enough bar. would be cool though.
Old 10-21-2004, 06:27 PM
thats what i was thinking. i dont know if it would fit right, and making it fit right i dont know if i would be happy enough with it to go through all that. ive been lookin at some pictures and i cant figure out what is on the front of the console, ahead of the map light?
Old 10-21-2004, 06:39 PM
it is a reminder spool, has several different things to remind you about, engine service, trips, mileage, the thing that sucks about it is you have to do it by hand.
Old 10-21-2004, 06:51 PM
ok now i kindof want one, cause i can never remember what mileage to change my oil on...ever
Old 10-21-2004, 08:59 PM
Dont forget theres 2 different versions. One for ttops and one for hardtops. One of them, i think the hardtop has a big curve to it while the ttop one I think is fairly straight. One might fit a 4th gen but you would have to do some custom work to mount it. If you went through that much trouble I would suggest getting a nice digital one from another car.
