Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-19-2004, 04:22 PM
mospeed1 mospeed1 is offline
Send a message via AIM to mospeed1
sts turbo
has any one seen these. http://www.ststurbo.com/home
it's a sytem that mounts the turbo where the stock muffler use to be.
it seems like a real easy setup to make
any comments?
02 rodeo ls
old ride 95 200sx full showcar
Old 10-19-2004, 04:49 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: sts turbo
remote turbos are nothing new, they're not much easier as you have to find a way to plumb the pipe all the way from that turbo back there to the throttle body.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-19-2004, 05:55 PM
454Casull 454Casull is offline
Re: sts turbo
You also get more turbo lag.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 10-20-2004, 12:21 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: sts turbo
Let's play a game of Spot-The-Bullshit!
From the website:
Benefits of Remote Mounting
Ease of installation. STS turbo systems can be installed in 4-6 hours with standard tools and average mechanical ability.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to bolt on using factory mounts without cutting or modifying your vehicle.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 2-4 mpg increase in gas mileage.
Lower underhood temperatures. No need to worry about melting wires, hoses, or other components.
Easily converts back to stock in less than an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to any of the engine components.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Built-in intercooling. Intake piping provides ~50% intercooler efficiency. There is no need for the expense, pressure drop, and installation problems associated with a front mounted intercooler.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise in the passenger compartment.
Quieter wastegates, especially if vented to atmosphere.
Better engine cooling capacity.
Old 10-20-2004, 02:20 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: sts turbo
im pretty sure there are elevendy billion posts about this already
