3.4 Engine swap
Hi I have an 86 GT with 188,000 kms ( four speed )on it and I am considering doing an engine swap, I want something easy and something thats not to expensive.
I am considering the 3.4 because the increase in power is pretty good and there are lots of them kicking around ( the ones from the 90s camaros and firebirds) I was wondering if that engine will need a new wire harness and were I can find them and also how much $ do you think I can do it for? |
Re: 3.4 Engine swap
New wiring harnesses are thousands of dollars, at least the one I checked on for a Beretta that had an engine compartment fire was ($2,399 direct from Chevrolet) so your best bet is Ebay or salvage yards, keeping in mind salvage yards normally rape the snot out of wiring harnesses when they pull engines. Because Camaros and Firebirds are popular, you should have better luck getting one for a decent price from someone doing a v6 to v8 conversion (Try the Camaro Forum here on AF) who no longer needs it. As far as the engine goes, the 3.4 block is almost identical to your 2.8, so it'll bolt right in with no heavy mods. The starter holes are on the wrong side of the block, but it's easy to drill and tap new ones on the correct side. The water pump plumbing will take a little home grown engineering but isn't too difficult.
Wanted to buy: 86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply. 74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!! 3Rd gen F body floor pans/camaro door skin (L) Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Re: 3.4 Engine swap
So, whats easier the 3.4 swap or a 350 because a 350 doesn't have much wiring am I right?
Re: 3.4 Engine swap
If you are using a Camaro 3.4 replacing your 2.8, the wire harness you have should suffice. Just use the Fiero intake and valve covers and when your done, it should look like a stock Fiero engine. (They probably need some cleaning). When you swap in a 3800, 3.4 DOHC or 350 new harnesses are needed and can get pricey and need lots of checking to insure they are correct.
Re: 3.4 Engine swap
So which is the easiest and the cheapest because I heard on this site were the guy did a 3.4 swap he said A new wire harness after you send in the fiero and donor car one is $350, so couldn't you just buy one without sending your own?
P.S I have never done my own motor swap and haven't any major work to motors but I know a thing or two how hard is the 3.1 conversion and how is the wire harness in that? |
Re: 3.4 Engine swap
I was gonna go for a 350 swap but after I looked at the cost i figured I might be able to do something alot cheaper. I was looking at just turbo the 2.8, but thenI thought if the 3.4 is a direct bolt in why not do that and turbo it.
So will the 2.8 wire harness work on the 3.4? Will the 2.8 computer work on the 3.4? Do all the mounts, the dog bone and the driveline shock bolt up to the 3.4? Will the muncie 4 speed bolt up to the 3.4?
Turbo 351w E85 |
Re: 3.4 Engine swap
Yeah could someone help with GoatNipples questions because I have the same ones and would like to know the answeres
Thanks |
Re: 3.4 Engine swap
The Camaro 3.4 can be a direct replacement for the 2.8 except the need to relocate the starter. I believe that the 2.8 ECM will work for the 3.4 and that the wire harness from the 2.8 will work with the 3.4. That is why this swap is one of the easiest. I even think that the four speed should mount to the 3.4 with the usual degree of difficulty putting in a transmission. I had the "ultimate" dogbone installed in mine and that is a direct replacement for the stock dogbone.
There were some modifications to my car for I had a 440t automatic installed at the same time the 3.4 was put in. The easiest way I've seen for engine swaps is to obtain a good cradle and install the replacement engine/transmission on that, then install the new cradle and engine. Especially if the car is used as a driver and is still in operating order. The car can be used while you make sure the new engine/transmission is all together |
Re: 3.4 Engine swap
For some reason I was thinking the 3.4's had TBI (duhhhhh I must have been sleepy that night) but yea, the 2.8 ECM will run a 3.4
Re: 3.4 Engine swap
What about the wire harnnes were can I get one because I heard they ran for about 400 when you send in a fiero and 3.4 harness so were will I get my hands on one, and also will the stock 4 speed work ?
Re: 3.4 Engine swap
There's no need for a new harness. The stock Fiero harness that's in your car now will work fine as long as the 3.4 you get is pulled from a car with a distributor, or you swap out the coil pack DIS for the Fiero's original distributor and coil (all you need to do is pop out the dummy plug for the oil pump drive and replace it with a distributor. The crank and cam sensors can be left in place unused, or removed and the holes welded shut and ground smooth). A 3.4 is no more then a bored and stroked 2.8, so the timing and firing order of the 2 engines are identical.
Re: 3.4 Engine swap
whats the hp difference between the 3.4 and 2.8??? just curious
Re: 3.4 Engine swap
So what year car does the 3.4 have to come out of so that it has a distributor
Re: 3.4 Engine swap
So basically all I will have to pay for is the motor and a rebuild if I decide on it because I will probably try to do the swap myself..one more question about the wiring, If in the fiero there is a wire that goes say to the coil or anywhere else will it go in the same place on the 3.4 or how does that work?
Re: 3.4 Engine swap
GM has always had a nasty habit of changing wire connectors a lot, so plugs aren't always what they need to be. The best way is to use the stock2.8 Fiero coil and distributor on the 3.4. Optionally, an aftermarket high performance coil designed for the Fiero will add a little ooompf to things. Aftermarket ignition parts should be ordered for 2.8L V6 86' Fiero, NOT a 3.4L Camaro, so the wiring connectors are correct.
You can also have your 2.8 rebuilt with a bigger bore and stroke, creating a 3.4 without buying a different engine. This eliminates any random swap hassles and starter relocation issues, and allows the use of stock exhaust if needed.
