Old 10-19-2004, 04:29 PM
bcampbell bcampbell is offline
Unhappy 98 grand prix gt steering problems....
i have a 98 grand prix gt and i think the rack & pinion is going out.
the steering always feels loose and so far i've had a broken sway bar fixed, i had a bolt missing from the subframe, and no matter what they fix, it feels worse. any suggestions?
Old 10-19-2004, 07:36 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 98 grand prix gt steering problems....
other than feeling loose, do you have any noises while turning or a "rumbling" feeling in the steering wheel? Normally a bad rack will exhibit one or both of these symptoms. IF not, check for bad hub bearings and/or ball joints, as they will give you a loose steering feel as well.
Old 10-22-2004, 10:22 AM
Re: Re: 98 grand prix gt steering problems....
yes, when i turn hard either direction it makes a terrible sound like i just turned it too far. and sometimes it sounds like its grinding or dragging something on the ground. when i first got the car, it was doing something similar and i had the wheel bearing checked but they said there was nothing wrong. when i hit bumps it feels more like 10 bumps and the whole car separates from the frame.
i've found a missing bolt from the subframe and a broken swaybar, fixed them, and it feels worse.
Old 10-23-2004, 06:35 PM
Phoenix69 Phoenix69 is offline
Actually, my steering also feels a bit loose. The problem doesn't affect me driving too much, I've grown used to it. I checked and found out there is a recall on the rack and pinnion. Take a look into it.
Old 10-25-2004, 10:24 AM
thanks
Old 10-28-2004, 10:12 AM
I checked out the recall and found that there are 3. thank you for the info. !!!
i'm taking it in on monday.
Old 10-28-2004, 11:00 PM
deb0704us deb0704us is offline
Send a message via AIM to deb0704us Send a message via Yahoo to deb0704us
bcampbell, hi, I'm new here. Where do you find out about the recalls? I have a 1998 Grand Prix and a 2000 Bonneville. Thanks.
Old 10-30-2004, 11:02 PM
http://www.mycarstats.com/auto_recal...AC_Recalls.asp
hi!
this should get you to where you can look around for what you need.
Old 10-30-2004, 11:27 PM
bcampbell, thanks for the information.
Old 11-01-2004, 05:29 PM
ok, I took it in for the recall and they said it's already been done over a year ago. they didn't even pull it into the shop.
so now what?
