Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 10-19-2004, 02:19 PM
79cj5_350 79cj5_350 is offline
Removing heads from a 350
This is probably a dumb question, but when removing heads from an engine, is it nessary to remove the rocker arms and pushrods first, or should it just come off with some coaxing? Also, when reinstalling afterwards do the rocker arms need to go back into the same old location or does it not matter? Thanks in advance.
Old 10-22-2004, 12:04 AM
ebu187 ebu187 is offline
Re: Removing heads from a 350
loosen the rocker arms,take the pushrods out in order to be safe (and place them in or,masking tape whatever) then it should just lift off
you might have to pry a lil ,get a manual or ask a shop for install procedure
Old 10-22-2004, 11:39 AM
Thanks, after i did all that, they came right off.
Old 10-30-2004, 08:05 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
did you remember the torque of the bolts?
If you dont get the correct torque, your screwed.
Old 10-30-2004, 08:15 AM
torque
85 lbs-ft
Old 11-01-2004, 08:04 AM
Is it still 85lbs-ft even though i changed the springs from 80lbs to 100lbs to work better with my cam?
