Go Back   Automotive Forums Car Chat > Nissan > Nissan 350Z/370Z | Infiniti G35/G37 Coupe > Performance > Forced Induction
Forced Induction Look here for information on superchargers and turbo kits for the 350z
Old 10-19-2004, 02:16 PM
iijrzpnoyii iijrzpnoyii is offline
Supercharged Turbo Vq35de?
Is It Possible To Supercharge And Turbo The Vq35de? When I Look At The Engine Bay It Looks Like Theres Room For Both A Turbo And Supercharger With Custom Piping. Have Both The Supercharger And Turbo Feed Into The Same Intercooler And From The Intercooler Blow Into A Single Pipe Into The Intake System. What Do You Guys Think? With Both Systems Youll Have Power Throughtout The Whole Rpm Range.
Old 10-19-2004, 04:27 PM
VQuick VQuick is offline
Re: Supercharged Turbo Vq35de?
Twincharging is a waste of money and time. With a properly sized turbo, you will have a very balanced powerband.
“What does ‘kouki’ mean? Are you saying my car is crazy or something?”
Scott-Revs: Motown Muscle
Old 10-19-2004, 04:51 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Hey! How ya doin' VQuick! Long-time no-see!
Twincharging is just an oddity... stick it out with a conventinal turbo or SC kit!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 10-19-2004, 06:59 PM
but wouldnt it be better if you had both? while your waiting for the turbo to spool, you have the supercharger in the lower end for power. it will also cause faster spooling of the turbo and have both working at the same time.
Old 10-20-2004, 08:15 AM
Amril Amril is offline
a properly refined turbo system will have little lag and once the turbo has spooled up all the supercharger will be is additional weight and a power robber.
And Do You Have To Have Every Word Begin With Capitals? It's Not Proper English Ya Know?
Everyone goes through random acts of stupidity, I just go through it more often than others
Old 10-20-2004, 08:19 AM
Re: Re: Supercharged Turbo Vq35de?
first of all, The Forum Made Every Word Begin With Capitals not me
how will the supercharger rob power? theyll both be blowing into the same intercooler. also the bigger the turbo the longer it will take to spool but it comes with a bang. so why wait and have no power if you can have a supercharger supply the power until the turbo is at its max.
Old 10-20-2004, 08:56 AM
Re: Re: Re: Supercharged Turbo Vq35de?
Superchargers run off of a pulley driven by the engine. It takes power from the engine to run that pulley. The supercharger effectively takes away power before it gives power. That's called parasitic drag.
That's why you don't get a 'big' turbo. With the new technology(ball bearing cartridges, variable nozzles, etc) available, you can get a bigger turbo than you would in the past, and have the same spool rate if not better.
Because you still haven't explained how to turn the supercharger off once the turbo spools, so that you don't have 50psi running through your engine for 10 seconds before it blows.
Old 10-20-2004, 03:06 PM
otter7467's Avatar
otter7467 otter7467 is offline
Send a message via AIM to otter7467 Send a message via Yahoo to otter7467
it just seems like a waste. plus if it was a great idea there would have been a race or supercar made with that setup already.
2004 GTO
04 350Z-Sold
04 Envoy-Sold
03 Gixxer-Sold
Old 10-20-2004, 03:38 PM
There were a few race cars that used it. I think one of them was a Group B rally car...but we all know the problems with them.
If you are going to be running such a big turbo, just use nitrous to aid spool-up. It's much easier to do, costs far less, and you can program the nitrous to switch off after the turbo spools. You can't 'program' anything on a supercharger.
Old 10-20-2004, 05:33 PM
350G's Avatar
350G 350G is offline
Save the money and get a sleeved block capable of holding over 700whp . . . combine that with a reputable TT system and you now have a powerful car . . . and no traction!
Old 10-21-2004, 08:17 AM
I rest my case.
Also once the turbo spools up the supercharger will be useless BUT it will still be attached to the crankshaft which will cause it to rob power. Superchargers do it normally but they give more than they take
Old 10-21-2004, 11:21 PM
350G's Avatar
. . . besides, I really don't see it fitting . . . doing the TT was cramped enough and you have to relocate a few items just for it to fit.
Old 10-23-2004, 12:01 AM
Zgringo Zgringo is offline
It seems like I go into this question everyother week or so, and being I have been involved in both for many years, both as a user in racing and as a researcher for Pratt & Whitney after doing much testing at the Uni. of Utah on this very subject, I figure I can add some input to this subject with the open mind as neather is best, both have good points and bad. Now their's some who like the turbo's more, which is OK, but most have false ideas about which is best and I'll try and clear that up. This I promise you, I well not get into any pissing contest with anyone who cannot back up what they say.
In the past the roots supercharger pretty much went unchanged and most engineering studies went into turbocharging, as the results turbo's are where they are today. But lately engineer's have been doing alot of research with screw type superchargers and are developing some really good systems as can be seen on more and more cars with superchargers. So which one is really best? Depends on how you use it, and how it's installed.
Now don't tell me that turbo's make power for free cause they use wasted exhaust gas, and superchargers use lots of power from the crank cause I'll prove you wrong and you'll eat your words, if your honest.
Read the following with a open mind and then lets dig into the meat of the turbo vs supercharger.
If you want well do this in 2 parts, the 2nd part being to remove the myth that a low compression turbo'd engine makes more power than a high compression engine, and this I promise you when were done with this subject you'll be able to speak with authorty with facts. Fair enough?
http://www.chimera.co.nz/300zx/
http://www.superchargeronline.com/content.asp?ID=19
http://interjunction.com/features/supercharging/
Old 10-24-2004, 08:17 AM
this isn't us saying turbo's are better than superchargers it's just us saying both under the hood is a stupid idea
Old 10-24-2004, 12:45 PM
It isn't a stupid idea. It was used on semi trucks, airplanes and a few race cars, it's just a different idea. Personally I don't think very pratical, but different.
