Old 10-19-2004, 10:39 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
auto to manual?
so im looking for a gsx.. but all i can find is auto gsx's i really want a 5sp.. is it hard to swap in a 5sp tranny? and also will you be ale to use the auto ecu? is it expensive? and how storng is the auto tranny? can it take 400hp (my goal)..
thanks
1
Shift_BOOST
97 s14
Old 10-19-2004, 11:12 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: auto to manual?
With less time than it took you to write this post, I did a quick search....
http://www.automotiveforums.com/vbul...earchid=572784
This topic has been discussed to death.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-20-2004, 12:51 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: auto to manual?
what he meant was (to make it short), thousands of dollars the last time i checked. $6000 in new eng area. unless you can do it yourself.
and yes.. it is possible 400hps. however, as you go as high as 400, certain rebuild needs to be done to the tranny. it'll prob costs you $1200-$2000 for a complete rebuild still better than the swap.
06 Charger SRT-8 black.
Old 10-20-2004, 04:46 PM
LostProphetGsX LostProphetGsX is offline
Send a message via AIM to LostProphetGsX
Re: auto to manual?
My gsx is Automatic and it still very sufficent =D! In the automatic you shift into 2nd at 6500rpms and 6000 for every gear after that so it really isnt too bad.
Old 10-21-2004, 02:43 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: auto to manual?
You can build up an auto tranny for about 400, which is what I pay for ONE clutch, and I buy a few per year. It is known to be good to over 400 WHP at this level. They hold up much better than manuals, just by design (planetary gear sets, etc). You can build boost on the line without a stutterbox (footbrake). They shift faster than any standard can when built properly. Etc. There are several advantages.
I have done an auto to manual swap on a 2G NT. Well, helped with it. The owner had to do all the spending and locating the correct parts, etc. We could only work for about an hour at a time since you would always run into some part you dont have. Then work for another hour 2 weeks later, etc. This continued for months on end
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
