Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-19-2004, 07:44 AM
nsheaffer nsheaffer is offline
5.9L Starting Problems
When I start the truck it turns over starts up but then shuts off right away. If I hold the gas on it runs fine. The funny thing is sometimes I start it and it will idle perfect.
All help is greatly appreciated.
Old 10-19-2004, 10:53 AM
tamuhill tamuhill is offline
sounds like it could be a fuel filter. you could try installing an in-line, clear body filter. cost less than $5 and you can see whats comin thru your fuel lines to know if you need to change the main filter also.
Old 10-19-2004, 10:28 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Re: 5.9L Starting Problems
Fuel filter, or TPS (throttle position sensor). It's on the driver's side of the throttle body and it tells the computer how much the throttle is opened. If it goes bad, the computer will tell the engine to idle too slow, and it will shut off. Also, it could be a valve that is somewhere on the throttle body that opens and closes when it is at idle. Sometimes they can go bad, or just get a little dirty. I'm not too familiar with that valve, but some other people on here are.
Old 10-20-2004, 07:10 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
The IAC (idle air control) valve is dirty or bad. Try cleaning it, and failing that, replace it. If you don't know what to do, go and buy one and then you'll know what it looks like so you know exactly what to remove and change. It's on the side of the throttle body, you'll probably have to take the air cleaner housing off to be able to see it.
My Mopars
Old 10-21-2004, 03:12 PM
LTJGWorth's Avatar
That's it. Thanks Bleed. The IAC. I knew it was something like that.
