Old 10-19-2004, 02:46 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
spark plug wires
all right...earlier tonight i got some 10.4mm spark plug wires...these things are massive compared to my old 7mm....now my question is.....when i'm idling and turn on defrost or A/C my rpm's get lower and my lights dim A LOT compared to before....earlier my car almost stalled lol....is it because of these huge ass wires drawing so much power or something?
Old 10-19-2004, 02:58 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: spark plug wires
Try doing an ohm check on the wires to see if they are within tolerance... They should be in the chiltons/hayes manuals.
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 10-19-2004, 08:50 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
shouldnt thincker wiresr have lesser resistance per unit/area due to there being more wire?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-19-2004, 01:17 PM
I have a set of 10.2 mm triple core wires and have had no problems.. I believe they would be more suited if you had an aftermarket coil and or a MSD ignition box that gave you more spark.
The wire does differ though... they have something like wire winding sizes... it changes its resistance and stuff.
I had seen a website awhile ago that explained it better than I can but can't remember what site it was.... sorry
http://www.mgbv8.org/ignition_system.htm
that might help...
Or This....................................
Open Circuit / Heat Resistance
Make sure the spark plug wire does not have an open circuit, and as a general rule, the resistance should not exceed 1,000 ohms per inch (but may be permissible by some O.E. manufacturers' specifications). To check, perform the following steps:
1. Remove the spark plug wire from the engine.
2. Using an ohmmeter, measure the resistance of the spark plug wire from terminal end to terminal end. If no reading is observed, the spark plug wire has an open circuit.
3. Measure the length of the spark plug wire in inches. Divide the resistance reading by the length of the spark plug wire to determine ohms per inch.
If I found it at one time you should be able to te he he!!!!!!!
Old 10-19-2004, 01:23 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: spark plug wires
Yep, provided that the wires are made of the same material, the wire with the larger cross sectional area will have less resistence. If I remember from physics class , resistence (in ohms) = (Length (in meters) * Resistivity (all materials are different)) / Cross sectional area (meter^2)
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-19-2004, 01:52 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
they may just be shitty wires... why the switch from the stockers?
Old 10-20-2004, 03:16 AM
in my book it says that on a 1995-98 2.0L turbo the resistance is supposed to be 22K ohms for all 4 wires. Also wires with excessive resistance will cause misfiring and may make the engine difficult to start in damp weather......
Old 10-20-2004, 05:52 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
i went to the 10.4mm wires this last weekend and i love them... evertime someone asks to see the motor they about shit their pants when they see the wires! they are huge... but i have never had any problems with mine, i switched cause i was having a major misfire so i swapped them out cause i got them for cheaper than i could get stock wires for... so i bought them, to complaints here!
