Back seats keep getting soaked!! help!!
Ok in my 92 lude, every time it rains my backseats get soaked, and i've looked underneath the seats and it's all orange and nasty from where water has been sitting, so i assume it's coming from beneath, because there's no water coming from the roof. So my guess would be leaking from the trunk?? There's a small amount of water coming in from the sides of the trunk but in the bottom of the trunk i noticed a big circular hole where i can see the exhaust and ground and everything. I guess when I drive it could get slung up through there?? Also, on my back glass the seal that runs along the bottom of it is not there. Any help would be appreciated.
Re: Back seats keep getting soaked!! help!!
Do your seats get wet if it rains and you're not driving it? If that's the case you know it's not from underneath. My friend had a 94 Integra that he had the same problem with. He later found out that his car had been in an accident before he bought it where the frame was twisted, and had a leak from the window that wasn't visible. See if it gets wet from just sitting, and not driving in the rain, then you'll know for sure where it's coming from.
Hey, I have the same car. And I have had a similer problem. All the same except I have the peice below the window, but all the holes for it are rusted out. when it rains watter gets in the trunk. and then a small bit of water runs down and gets under the seats from the trunk. You need to replace that seal and you'll be good to go. I on the other hand have to put a bondo type stuff along the whole part of the body, and then press the peice down so that it is sealed.
John 3:3 Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God." |
Yeah mine has holes where the seal is supposed to run, on the bottom of the back glass. There were black things in them that connected to the window, so i had to put little pieces of metal over the holes and silicon around them, but it still leaks. Is the seal that goes around the back glass, go all the way around it? So i'd have to replace the whole thing? Cuz they're really expensive you can only get them from the dealership.
