Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-18-2004, 09:26 PM
ainsley ainsley is offline
1997 pontiac ssei problems please help!!
I have a 1997 pontiac bonneville ssei with the pass chip in the ignition. My security light has been on for a while and when I went out to start it tonight the car turned once stopped and then everything was dead. I waited 5 minutes everything back to normal.I tried again and the same thing. I waited a gaina nd tried the spare ignition key with the pass lock and it did the sam ething. Any suggestions??
Old 10-19-2004, 09:48 AM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Re: 1997 pontiac ssei problems please help!!
Sounds to me like a bad battery connection...it has a good enough connection to run all the accessories but not good enough to pass enough amperage to start the car.... It could also be a bad battery.
Old 10-19-2004, 10:07 AM
1997 pontiac bonneville ssei with problems
As soon as the key was turned that's when the power went out. Is it still possible that it's a bad battery connection?? When it did turn over I stopped the starter as I thought t was running and it was not. Then turned key over and no power. Not even a click interior lights, headlights nothing worked. SAt for 5 minutes and then it had power turned the key and again no power to anything.. I will try to reset the battery cables and try again though I appreciate your answer if it's that then yee haa if not crappy!!
Old 10-19-2004, 12:24 PM
thanks fierce GT
If you lived near me I would buy you a beer or a few. It was a loose positive cable connection!!!
It felt tight last night but it's -10c here and well everything is cold. It was wierd that it would turn then everything was gone.
thanks again.
