Old 10-18-2004, 08:09 PM
farmboy farmboy is offline
Sloppy 5 speed
I have a '94 2500 4X4 with a 5 speed manual transmision mated to a 350. i recently replaced the clutch and when i put everything back together the transmision is very sloppy in shifting. Any suggestions?
I also am wondering if any one knows how to bleed the hydrolic clutch line i think it got some air in it during the job?
Old 10-25-2004, 07:17 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: Sloppy 5 speed
You should have replaced the hydraulic slave cylinder while you were in there. 9 times out of 10 the slave has wear on the area the throwout bearing rides on. It adds about $50 to the clutch job but well worth it. You may even consider replacing the clutch master cylinder too. It's only plastic and it wears much faster than a metal counterpart. As for bleeding, you need a helper to apply the clutch as you get underneath and crack the bleeder valve to expell any air that might be in the line. It's not any different from bleeding brakes, except that there is only one bleeder, thank God!!
Old 10-29-2004, 11:15 PM
Re: Sloppy 5 speed
Thanks i think i got both problems fixed i missed a piece when i put the tranny back together and i bled the clutch line and that fixed the problem for the most part i think the slave cylinder might be on its last leg but untill it fails completely ill keep runnin it
