Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 10-18-2004, 07:35 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
AWD conversion is about to begin
Just as an update, I got back from Baltimore a week ago and brought home my newest DSM (brings the total up to 3 )
Here's the story:
http://www.automotivearticles.com/AW...WD_Shell.shtml
It was quite an interesting experience.
I'll be posting updates as I get started tearing down the Talon and the Eclipse.
-Jacob
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 10-18-2004, 07:59 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: AWD conversion is about to begin
Good luck on the conversion
For Sale 98 Eclipse GS, 5 spd
Old 10-18-2004, 08:14 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Nice to hear that you are ready to start.
Was the info I pm you useful?, could you understand what i was trying to say? .
if you don't, sorry but english is my 2nd lenguage, tell me and i will try to rewrite it. peace
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 10-18-2004, 10:19 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
what about an all wheel drive Rs? haha maybe a good gain or no point?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 10-18-2004, 11:19 PM
aves911's Avatar
Massive Genius
Diego,
Your PM was very informative, the only thing that would be nice would be if you could get some pics of the front bolts for the rear end. The ones where you drilled and put the old GS-T bolts through. Just so I can see before I start on it.
As for a AWD 420a, the driveline won't bolt up, the N/T motor and tranny are reversed from the Turbo.
-Jacob
Old 10-18-2004, 11:29 PM
i won't have my camera until wensday, i will try to upload some pics on wensday or thurstday.
Glad to hear that the info i gave you helps.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 11-29-2004, 12:27 PM
Jacob,
when are you going to post some pics of your project, i will like to see what you did and how long it will take untill you finish it. i'm almost sure that you are going to finish it before me .
-Diego
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 11-29-2004, 06:19 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
ya ,you had to make at least alittle progress did you not? update....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-30-2004, 11:22 PM
aves911's Avatar
Massive Genius
I've got at least a hundred shots taken so far, they are all in the camera downstairs right now. When I finish the write up for this is going to be pretty lengthy.
As far as progress:
I've got the GSX tank and rear end put in the car
The fuel pump and senders are wired in
E-brake cables are installed
Most of the rear suspension is in (I had to order some new control arms to replace bad ones)
I'm getting ready to drill off the driveshaft brackets from the GSX to weld them onto the GS-T.
Most of the "custom" work is done, a little welding is all I've got left. Although I probably won't be done with the entire swap for a while longer because I'm still working with TRE on building an uber tranny.
I'll post up a couple pics in this thread tommorrow.
-Jacob
Old 12-13-2004, 05:36 PM
2of9 2of9 is offline
ok...lets see the pics. How long did this AWD conversion take?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-14-2004, 01:50 AM
aves911's Avatar
Massive Genius
What kind of pics do you guys want to see? The pictures themselves really don't mean much without an article to go along with them. But if there is something you would like to see, I'll post a pic up.
As far as a timeline, mine is taking longer than necessary. I completely dissassembled the rear end, cleaned the control arms, replaced some, replace sway bar endlinks, greased all the bolts, replaced diff fluid, resurfaced rotors, painted calipers, and am waiting on a built tranny.
If you were to just use straight donor parts this could really be done in a crammed weekend.
-Jacob
Old 12-21-2004, 03:59 AM
MarkDML MarkDML is offline
Send a message via AIM to MarkDML
If i am not mistaken, the Evolution engine and tranny can work with the GS body..
1. similar location for the transmission,
2. similar location for the intake
3. you can convert your gs to an awd evo motor and tranny
a friend of mine is working on that
Mark DM L
V8 Hunter
Rice Burner
Old 12-31-2004, 12:01 PM
i'd love to see that in the works MarkDML. post some pics when ever you can.
--2OF9--
#808/1000
Old 01-06-2005, 02:14 AM
aves911's Avatar
Massive Genius
The 420a to 4G63 swap is an unbelievable amount of work.
-Jacob
Old 04-05-2005, 04:56 PM
ArchidamusR ArchidamusR is offline
Send a message via AIM to ArchidamusR
Hang on, my '92 Laser RS (which to my knowledge has no functional differences from an Eclipse GS) has a naturally aspirated 4G63 engine. Did that get changed a few years down the road? I'm interested in upgrading to a g2, is why I ask... The less I have to wrestle with, the better.
Of course, if I could convert my g1 to AWD and get a turbo 4G63...
