Old 10-18-2004, 06:34 PM
Mendari Mendari is offline
Question Security & Anti Theft
I've spent a lot of time searching for security & anti theft products. In particular, I've been looking for Hood Locks and Gear / Shifter Locks. I've only found these two links.
Gear Shift Lock
http://www.globalsources.com/si/600...-GetProduct.htm
Hood Pin Lock
http://store.summitracing.com/defau...od+lock&x=0&y=0
Anyone know of any other options?
Old 10-18-2004, 07:35 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Security & Anti Theft
broken links. you need that ... part in each link
Empty Pockets Racing Member #1
Old 10-18-2004, 08:13 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
I got a fuel kill switch
Old 10-19-2004, 11:12 AM
Sorry about the broken links,
This will take you to Summit Racing, Search for part # 1472.
Hood Pin Locks
This will take you to some wacky importer/exporter site.
Gear Shift Lock
Old 10-19-2004, 12:02 PM
GScivic7's Avatar
A good car alarm installed by a professional.
Not much you can do to prevent theft, just fuck with them long enough so that either they just give up, or so that you can come running out with the louisville slugger. If a theif is determined to, they will get your car.
Old 10-19-2004, 12:29 PM
Kafziel's Avatar
Kafziel Kafziel is offline
Studies have shown a direct relation between proximity to warm-weather urban areas and instances of unplanned automotive deficiency.
In other words, get the hell away from LA...
Silver 1997 Civic EX Coupe
Old 10-19-2004, 12:46 PM
Beastiek2's Avatar
Banned
What was the #1 stolen car this year?
Old 10-19-2004, 12:47 PM
Re: Re: Security & Anti Theft
Originally Posted by GScivic7
Not much you can do to prevent theft...
I must disagree, a Yugo is an excelent theft deterent.
Old 10-19-2004, 12:57 PM
Kafziel's Avatar
I think it was something stupid, like a Saturn.
Old 10-19-2004, 01:17 PM
I'm planning to remove the manual hood release cable and replace it with an electronic trunk opener and adding the lockable hood pins from the link above. That way the thief can't get to the engine compartment to disable the alarm.
I also plan on cold welding (using J.B. Welds ) some jagged tin plates to protect the hood release mechanism. I'll take pictures and tell you guys how it went.
Old 10-19-2004, 01:20 PM
GScivic7's Avatar
I remember someone doing the same with razor blades in his center console for when people try to jack his HU. It worked too, said that the HU was about half way out and there was a trail of blood leading out of his car and down the street.
Old 10-19-2004, 02:27 PM
Razor blades,... I like the sound of that.
Old 10-19-2004, 05:56 PM
Beastiek2's Avatar
Banned
Re: Re: Re: Security & Anti Theft
Yup your right 95' Saturn SL, I think my X has that I hope hers was one of them.
2000 civic was #10 on the list
Integras occupy 4 thru 8 on the list
Old 10-19-2004, 09:23 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Get those funky hood pins used on racing cars. Instead of using the huge cotter pins, use small locks with keys. That way they'll have to work harder to get inside the hood.
Also, get a real good alarm installed by a professional shop. DEI is the best around. You can have them install special sensors in areas around your car like mercury tilt switchs, motion detector, digital tilt sensors, and backup batteries for both the alarm and siren. DEI also makes a hood lock that works pretty well. Also, DEI has come out with these SSKR relays. They are small relays the same size as the ones in most cars. The difference is that they have a small reciever inside that works with the remotes from the alarm. You replace the OEM relay like your fuel pump or starter relay with one of these. They'd have no idea what's going on. They work great at my shop. People love them.
Old 10-19-2004, 09:34 PM
GScivic7's Avatar
that's what he's talking about.
