Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-18-2004, 04:36 PM
xxjojoxx xxjojoxx is offline
replacing wiper motor
im trying to replace my front wiper motor.. but i cannot get the wipers off(not the blades, the entire wiper).. how do they detach?
Old 10-19-2004, 05:06 AM
Cam7 Cam7 is offline
There is a small latch at the bottom o the wiper arm. Pull out on the latch and then you should be able to pull the arm off. Sometimes you have to use a screwdriver to help pry off.Carefull not to damage the paint!
Old 10-20-2004, 08:37 PM
Re: replacing wiper motor
thanks... i got them off.. i changed the wiper motor, but the wiper delay stil does not work... do you know if it has something to do with the switch on the steering column?
Old 10-20-2004, 10:33 PM
esfd455 esfd455 is offline
Smile Re: Re: replacing wiper motor
When you run your wipers do you have slow/fast/delay modes? Or do you just have delay? When you turn off the wipers do they park back in the fully down stored position or do thye just stop where they are? If these problems are what you have it is not the motor or the switch on the column. Take the panel off the lower left side floor area by your feet on the drivers side. Right under the brake release handle. There you will find a DELAY CONTROL MODULE. Its a black box about 4" x 4". If you open up the box after removing it from the eletrical plugs you will see a circuit board inside. Take it out and look on the underside of the board where the solder traces are for the circuit. You will see a burned out or broken trace. If you solder acroos the break with some solder and a small piece of wire you will fix your problem. My JGC '94 had this problem and I went thru the whole thing with a motor and switch until I found the post on the internet about the circuit board. Hope this helps you.......
Old 10-20-2004, 10:57 PM
hi there.. you stated exactly what my problem is.. (wipers do not return when shut off & delay).. i am going to check that box tomorrow.. sounds like it's the problem.. thanks so much in advance
Old 10-20-2004, 11:30 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
does this work for the Rear Wper as well, I have a problem with my rear wiper they don't work at all now, before they would start wiping then start to slow down to the point where they did not move, I would shut them off for awhile and then turn them back on and they would do the same thing. now they just don't move at all.
Old 10-21-2004, 06:21 AM
Cool Re: Re: replacing wiper motor
Your problem sounds more like either the motor for your rear wipers has gone bad or the linkage is very dry and is not letting it rotate softly. The fix stated above is for the speed and park positions only. If they run only on slow and fast and do not have any delay and also does not park back in the home position then the box is the problem. Yours sounds like the motor/gear box in the rear tailgate has taken a dump.
Old 10-21-2004, 09:43 AM
shamza shamza is offline
The small electronic gizmo (intermittent wiper control) to the left of the drivers feet is the culprit.
If you have some understanding of basic soldering you may be able to fix this problem yourself.
Just open the box and look pry out (carefully!) the circuit board. Look carefully and you will see a bit of the printed circuit is burnt. Just solder a jumper over and viola!
I did this to mine and it has worked perfectly since. There were some posts with diagrams and pictures of this but I just cant find it any more
Good luck!
Shafeeq
