Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-18-2004, 04:32 PM
ZJbumping ZJbumping is offline
Steering Clunk, Pop.
I have a 98 Grand Cherokee 4.0L.
I have this noise and it is located somewhere in the steering. Sitting in park with jeep running, i turn the wheel completely to the right, i hear a one time clunk or pop . I turn the wheel completely to the left, i hear a one time clunk or pop. What could be causing this, i have new CV joints, rotors and brakes upfront. Its just annoying your while parking and i want to get this solved before it leads into something worse.
I just got my power steering pump replaced at a local jeep dealership here in Mo-town, and this just started. This problem does not exist while traveling down the road. I tightened all my lugs in the front thinking that they might be lose, didnt solve anything. If anyone could help, drop me a post, i would GREATLY APPRECIATE IT!!!
Old 10-18-2004, 05:55 PM
jeeperphil jeeperphil is offline
Re: Steering Clunk, Pop.
kinda sounds like a cv joint. if the boots are good then the joints are likely to be good too. also look at tie rod ends.
Old 10-18-2004, 06:37 PM
tire rod ends.....
I know it cant be the cv joints, just replaced those 5k miles ago + the boots are in good condition. Could be the tie-rod ends.....is there anything specific i should look for in the tire rod ends????????
Has anyone else noticed that cold weather brings out all the "weird noises" in Jeeps??
Old 10-19-2004, 04:18 AM
Cam7 Cam7 is offline
Jack up the front of the Jeep and turn the wheels and see if you hear anyhting.If nothing grab tire top and bottom and see if you can move it at all. I have ahd bad wheel hubs act like that.
Old 10-19-2004, 07:56 AM
Caribbean ZJ Caribbean ZJ is offline
Could be the stabilizer bar bushings. cheap fix.
Old 10-19-2004, 08:46 AM
Yea, that crossed my mind about the stabilizer bar. I will check it out this weekend.
Anyone have any other IDEA's, of what this problem could be???????
I would appreciate any and all ideas witht his one!!!
Old 10-19-2004, 03:57 PM
I just hope my Fu$@ing tire doesnt fall off, could that happen?????
Old 10-29-2004, 09:28 PM
CapeFear562 CapeFear562 is offline
something is loose, hard to tell what from here but as said jack it up and have someone turn the wheel while you watch and LISTEN. if its only popping once then it aint the CV joints because of the nature of the design.
Old 10-30-2004, 10:46 PM
Hey, just solved the FuKing problem. A control arm was loose up in the front end......i was wondering why i could feel it in my feet.
