Old 10-18-2004, 04:10 PM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
Revell 1969 Camaro Yenko 427 Coupe
Yeah, bought the model, and have been working on it for a while, and will get pictures of my progress soon.
One problem I am having tho is getting the wheels to stay on the axle, front and back. In the directions it shows to just push them on, but they either fall right back off, or dont go on at all. Anyone build this kit and know what to do?
/edit: Oh, and I plan on making a COPO camaro out of this, so no fancy badging, no stripes, just plan camaro with a 427 under the hood. I would like to use reg camaro wheels, but like i said, none want to stay on =(
Old 10-18-2004, 04:25 PM
will69camaro will69camaro is offline
Send a message via AIM to will69camaro
Re: Revell 1969 Camaro Yenko 427 Coupe
remember to paint the reg wheels body color where there isn't a cap or trim ring to be authentic...even cooler paint the engine aluminum and make it a ZL1 clone That's what i plan on doing when i get that model.
Old 10-18-2004, 04:29 PM
Jaymes's Avatar
Jaymes Jaymes is offline
about the rims... you need to push them in harder to get them in. be careful not to break anything though. good luck!
Old 10-18-2004, 07:08 PM
primera man's Avatar
"P-Man"
The end of the axle should flare out on the tip so the wheel can be pushed on and stay in place....you haven't cut it to short when removing it from the sprue?
View All My Models Here.
Old 10-18-2004, 09:15 PM
cooltc2004's Avatar
the thing was I followed directions, so I was putting the wheels on when it was all assembled. That might not sound like a problem, but when I tryed to put on the front wheels, the upper control arms would pop off. I managed to get it tho, thanks everyone for your help. Pics will come soon.
Old 10-19-2004, 09:53 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
On those kits I attach the wheels/tires to the lower control arms piece before cementing it to the chassis. You can get more straight on muscle to snap the wheel on without bending the spindle & control arm that way. This is the same basic kit, built out of the box, but with the small block. - Mark
Old 10-19-2004, 08:51 PM
Jaymes's Avatar
underbody looks incredible! But you should start a thread in the In progress section.
Old 10-19-2004, 09:45 PM
cooltc2004's Avatar
wow that looks incredible, makes mine look like childs play. Thanks for the tip btw
/edit: How did you get the black plaint like that, that isnt just flat black is it? Also, any tips for keeping a steady hand when painting the brake lines?
Old 10-20-2004, 10:08 AM
Thanks, this one is done, I can post the finished pics in the Street section. It was a quick one week out of the box "cannonball" build.
For the chassis, I started with a base coat of flat black, just use your favorite. Then I airbrushed thinned out medium gray, dark gray and some earthtone browns and dark tans lightly over it repeating the colors on top of each other until it looked right. A little splattering is ok, it doesn't have to be uniform. Then I gave it a wash of dark gray to blend the colors into a light grime look, let fully dry, and then sporadically dry brushed medium gray to pick up the highlights.
For detail painting I use a regular liner style brush No.2 size. The larger bristles keep wet longer and therefore make a smoother line. Keep it wet, but not saturated and don't be afraid to make mistakes. If you do, fix them. If you know how to fix your mistakes you'll be far less likely to make them. And just practice.
Here's a shot of the engine bay. I used the same light weathering approach with washes and dry brushing on it too. It's meant to portray a used, but well maintaing vehicle. - Mark
Old 10-20-2004, 02:30 PM
76 maverick's Avatar
76 maverick 76 maverick is offline
Great detail on the engin bay , looks like a real brake booster there ! Just a tip for the carbs; you could drill the four holes in them to make them a little more real (not that you need to they look great)
"I live in my own mind , an`t nothing but a good time , no rain just the sunshine out here in my own mind"
Old 10-20-2004, 02:54 PM
No, that's not allowed in the IPMS Out Of The Box rules. But there is venturi detail in there that I added, you can barely make it out in this shot, much easier to see in person. - Mark
Old 10-20-2004, 03:09 PM
oh well that sucks
Old 10-20-2004, 03:16 PM
"P-Man"
Great looking detail work.
Old 10-21-2004, 07:49 AM
cooltc2004's Avatar
any tips on painting the camaro logo on the front and rear of the car so it looks like it should, not paint all over the place? Little harder to touch up your mistakes on a fixished body. (Ill look at my detailing kit, it might have one made out of metal.)
Old 10-21-2004, 10:00 AM
The Pace Car and the SS396 kits by R/M come with those scripts in the box on the Scale-Master decal sheets. The SS396 kit would be the better choice in my opinion, the printing quality is better and there are more decals on that sheet.
Otherwise, I would just use the same brush I described above with your favorite enamel, not acrylic, chrome silver paint. - Mark
