Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-18-2004, 03:52 PM
eli323232 eli323232 is offline
throttle body
Hey everyone, my 93 lx has a few mods, full exhaust, bigger mass air, I was wondering whether I should get a 65mm or 70mm throttle body. I think those are the only two I should be considering, correct me if i'm wrong.
Old 10-18-2004, 05:19 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: throttle body
65 mm will be plenty with your mods.. 70 mm is a little overkill...
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 10-18-2004, 06:07 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Your stock 60mm should be fine for a while. Until you upgrade any h/c/i/ components the stock will flow plenty enough air for your needs.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-19-2004, 03:25 PM
Re: throttle body
Thanks guys
