Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-18-2004, 03:14 PM
sharklover94 sharklover94 is offline
Send a message via Yahoo to sharklover94
1996 saturn SL-2 rear window off track
my left rear window went off track yesterday afternoon and when i went to pull off the door panel i found i couldn't. i can normaly fix this problem easly with my other cars but this is the first time i have had to deal with it in the saturn. any advice on how i can pull the panel off and put the window back on track??
thanks
Old 10-18-2004, 07:09 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
Re: 1996 saturn SL-2 rear window off track
well there screws hidden in the panel...i dont know exactly where...so don't pull too hard...but once you get it off you probably need to loosen some bolts on the track in order to get it back on track...
Old 10-18-2004, 11:30 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
the outside panel or the inside panel?
you may also want to read this. you may need a saturn special tool for the regulator, but i hear those 6-sided cube-shaped disk-brake piston adjusters work.
