Old 10-18-2004, 11:45 AM
aal's Avatar
aal aal is offline
engine swap advice needed
91CRX DX
how much does a D15B2 weigh?
Can I pull and place it by hand(with help) or do I really need a lift/comealong?
Old 10-18-2004, 07:18 PM
NerveAgent's Avatar
NerveAgent NerveAgent is offline
Re: engine swap advice needed
Originally Posted by aal
91CRX DX
AHAHAH are you serious?!?! Dude you need a crane.
Old 10-18-2004, 07:22 PM
travagliante's Avatar
travagliante travagliante is offline
due no you dont. A d15b3 with or without the tranny weights no more than 350lbs. tops! So im sure if you had like 4 friends holding it up and you putting the bolts in it can be done.....
Get like a metal fencepost and tie some ropes around the engine and hang it from that.
Or you could always jack the car up high and then drop the body on it.---thats what i did with my integra. Worked fine, just watch out for suspension and motor mounts go on last.
Old 10-18-2004, 08:38 PM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
^^^agreed it can be done, but a cherry picker makes it so much easyer
Old 10-18-2004, 09:04 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
http://honda-tech.com/zerothread?id=466327
