Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-18-2004, 09:52 AM
vette eaterr vette eaterr is offline
OBD Codes
I looked up how to jump the wires to read the trouble codes, but my connector has leads in A, M, O, & P | F | E | D | C | B | A |
| R | Q | P | O | N | M |
Is this OBD II? if so what do i need to scan the codes, i have an OBD II scanner but it's only for the 16 pin connector.
Thanks,
Bob
Old 10-18-2004, 10:03 AM
Re: OBD Codes
It is a 1995 with a 3.8l
Old 10-18-2004, 11:46 AM
LMP's Avatar
LMP LMP is offline
Re: OBD Codes
I think it has been said on this forum that 1995 was a swing year and that there were OBD1 as well as OBD2. If the connector you are talking about is the CAR connector, then it is probably OBD2 because OBD1 (on my car) has only 3 wires connected to the car plug.
About OBD2 scanners, there are multiple configurations depending on car maker: ford, GM and chrysler as well as imports are different....
Old 10-19-2004, 08:12 AM
Re: OBD Codes
Granted, but what OBD II scanner will read from a 12 pin DLC? Is there some sort of adapter from the 16pin to the 12 pin GM style? What is everyone else useing?
Thanks
Bob
Old 10-20-2004, 03:27 PM
LMP's Avatar
LMP LMP is offline
Re: OBD Codes
This 12 pin connector is just like mine: OBD1
see www.avigex.ca/plug
You can read codes by jumping connector A and B and switching the ignition key ON, and reading the flashes of the Check Engine Light.
Old 10-20-2004, 03:28 PM
LMP's Avatar
LMP LMP is offline
Re: OBD Codes
...well, in fact, not exactly: mine has connectors in A,B and M only...so back to square 1
Old 10-20-2004, 04:27 PM
nicke66 nicke66 is offline
Re: Re: OBD Codes
As far as what I have been reading, what I have been told, and also accordning to my experience, all 1995 Trans Sport has OBD I (Some other car went to ODB II already in 1995). But you are right, It has been said on this forum that there were both OBD I and II in 1995.
In any way, 12 pin connector meen OBD I! You need and interface, an old laptop and some software to read out the data and the error codes.
Some useful links:
interface: http://www.pontiac-interface.de/index.html
Software: http://www.pontiac-transsport.de/index.php
Up to 1992 it is also possible to read the error codes via the check engine light, but not for 1993 and later.
Best regards
Nicke (Sweden)
Old 10-20-2004, 08:01 PM
LMP's Avatar
LMP LMP is offline
Re: OBD Codes
I do read error codes via the check engine light on my late 1993 Xport
Old 10-23-2004, 05:00 AM
Re: Re: OBD Codes
Well, I might be wrong about the year. Maybe it is possible upto 1993/1994 to read error codes with the check engine light. At least I know that it is not possible for my 1995 and later.
Old 10-23-2004, 07:53 AM
LMP's Avatar
LMP LMP is offline
Re: OBD Codes
Yeah I would think the difference in socket connectors (AMOP vs ABM) reveals the change.
Old 10-25-2004, 06:49 PM
ciras3's Avatar
ciras3 ciras3 is offline
Re: OBD Codes
Hi,
1995 is a weird year. You need to have a scanner that reads OBD II codes and then you need an OBD I cable. I have a 1995 Trans Sport with the 3.8. My scanner is the AUTO X-RAY OBDII scanner but I had to go and buy the OBD I GM cable. When I read my codes, they are OBD-II codes. Don't even try to use a paper clip and jump the connections because it won't work.
Hope this helps
"Just because the cat has her kittens in the oven doesn't make them biscuits."
Old 11-13-2004, 09:21 AM
Thanks Guys!!!!
Old 11-18-2004, 03:12 PM
Re: Re: OBD Codes
Yes, you are right. I have AMOP connected in the socket of my -95 3.8, and then it is pretty clear that there is no idea to try to jump the A and B with a paper clip....
I did made an interface instead and downloaded the software from the link above. The interface did cost me about 10$, I did have an 10 years old laptop to use and the software is freeware. You donīt have to spend 100dreds of $ on expensive scantools.
Old 11-19-2004, 10:29 AM
Do you have plans for the interface? parts list? and cable wiring scem's?
Thanks
Bob
Old 11-23-2004, 03:55 PM
Re: OBD Codes
Thanks
Bob
All you need is in this links:
interface: http://www.pontiac-interface.de/htm/...face_Meyer.htm
Software: http://www.pontiac-transsport.de/mod...download&cid=1
Do not let the German language scare you away. I did make the interface after Carsten Mayers layout. Parts did cost me about 10$.
Download the software and run. If you need any help, please ask.
/Nicke
