Old 10-18-2004, 05:58 AM
TwentyPints TwentyPints is offline
One thing not right
how do i get the front part of my truck to sit level with the rear. is this normal? or is it cause there's no load in the back?
Old 10-18-2004, 08:34 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Re: One thing not right
is it a 2wd?
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 10-18-2004, 09:39 AM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
This is normal, so that it won't sag grossly when loaded up. You can buy leveling kits. I'm sure someone on this board can recommend a good one. Personally, I like the leaning look, I think it makes it look aggressive! Of course, I assume you have a 4WD. The 2WD 1500 sits level, or at least much closer to it than the 4x4.
Old 10-18-2004, 10:31 AM
no its a 2wd...you can tell there is a bit of a lean there.. not a huge deal, just like it more level like some i've seen.
Old 10-18-2004, 10:56 AM
Nigel215's Avatar
yea...i have a 2wd and it leans forward a bit. actually, i have a 2000 and my dad has a 2002 and his sits level. I donno wht. Would it have anything to wo with a reg cab and a ect. cab?
I thought a 4wd wouldent do it as much becaus they sit a bit higher that a 2wd.
Old 10-18-2004, 11:16 AM
chuck16's Avatar
chuck16 chuck16 is offline
R u guys talking about the raked look? or Level when looking dead on from the back or front?
All the Silverado's do it. They all are a little lower in the front then in the back.
The problem I have with mine is that it sits down on the driver side just a touch when you look at it from behind. I think I may have a tired spring on the Driver side of my truck but, I'm not sure at this point.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 10-18-2004, 02:03 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
a 2" lowering kit on the rear will level out a 2wd perfectly. East to do and inexpensive.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 10-18-2004, 03:36 PM
what about raising the front instead to make it level with the back?
Old 10-18-2004, 05:21 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: Re: One thing not right
You just need to cut down on those late night snacks
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 10-18-2004, 06:28 PM
chuck16's Avatar
LOL.... yeah. Oink, oink too many cookies... ((From Flight of the Navigator))
2008 GMC ACADIA
I AM Canadian!!
Old 10-18-2004, 08:32 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Okay, here's what you need. If you want to level the back of the truck, all you need is a 2" lowering shackle(obviously you need 2, one for each side). Real cheap, you can find em for $40 or cheaper, look on ebay. If you want to raise the front, you can get a set of 2 inch lift springs. Should be had for around $70-$100. Prices on both could be way off. It's been a long while since I've priced anything.
*Under Construction - New sig to debut*
Old 10-18-2004, 08:49 PM
any certain brands i should look for?
Old 10-19-2004, 12:21 AM
silveradoman silveradoman is offline
So why does mine look so level?
Old 10-19-2004, 04:22 AM
skipr skipr is offline
On my 1984 C20 is put big block springs in front. And with a 350 cid inr there the heavier duty springs made it sit high in front .
Old 10-19-2004, 08:31 AM
For lift springs I'm not very educated on good/bad brands. As for lowering shackles I would go with DJM.
