Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-18-2004, 04:41 AM
ansdy ansdy is offline
Single cylinder
Im looking at running some form of supercharger/ Turbo with a 450cc single cylinder 4 stroke bike engine as part of my degree. I've got a reasonable knowledge of adding a compressor to a 4 cylinders + engine but cant find anything relating to a single cylinder. The best part is we have to run a 20mm restrictor! Any help or opinons would be great
Old 10-18-2004, 10:55 AM
SaabJohan SaabJohan is offline
Re: Single cylinder
There isn't any difference in adding forced induction to a single cylinder engine than an engine with more than one cylinder. Perhaps it's a little easier since the cylinders can interfere with eachother.
Old 10-20-2004, 05:21 AM
ok thanks for that, do you think that the 20mm restrictor and a compressor would work ok? the throttle body and restrictor must be placed before the compressor though.
Old 10-20-2004, 04:45 PM
Re: Single cylinder
20mm restrictor and throttle body before the compressor... sounds like Formula SAE.
Yes it works, however, a turbocharger has the advantage that a higher boost can be used at lower engine speeds allowing max power during a wide band. Like the WRC cars for example, above 300 hp whole the way from 3000 rpm to redline of around 7500 rpm.
Old 10-20-2004, 09:43 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: Single cylinder
wowzerz, get some type of charger on that bike and you'll be haulin!
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
