Old 10-17-2004, 11:45 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
interferance motor?
is my ZC an interferance motor? the reason i ask is cuz my timing belt slipped quite a bit tonight again. more then the last time. the car still ran ok except it sounded like it was only on 3 cylinders and it kept trying to shut off on me on my way home (i was about 5 mins from my place) so i just drove it home. do u guys think it mashed any valves???
Old 10-17-2004, 11:48 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
Re: interferance motor?
You would know it if you hit valves on the pistons, its audible. Do you have a cheap aftermarket adjustable cam gear?
Old 10-17-2004, 11:51 PM
1PhatCX's Avatar
nope. its the stock cam gears on there
Old 10-18-2004, 01:58 AM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
how the hell does your timing belt keep sliping......tighten your damn tentioner.
89 DX: LS Powered
88 CX: Project ZC
Old 10-18-2004, 11:08 AM
1PhatCX's Avatar
the tensioner is tight, theres no slack in the belt and it keeps skipping teeth
Old 10-18-2004, 11:59 AM
dxhatchback dxhatchback is offline
maybe the lower gear is stripped/rounded off??
Travis
HONDA is the BOMB!
Old 10-18-2004, 12:29 PM
91civicDXdude's Avatar
yes the engine is interference. I'd say there is a chance the piston hit the valves. set your engine back at TDC and then do a compression check. If a cylinder comes up low, or multiple cylinders come up low, chances are you have a bent valve.
As far as the issue of skipping teeth.. it could be a number of things. you could have a defective tensioner that isnt holding tension. I would also check the distributor, as i have heard of ZC's having problems of the distributor locking up or being very hard to turn and this in turn holds up the intake cam and the belt will slip on the cam gear. remove your timing cover and crank pulley and inspect the lower timing gear and water pump gear to make sure they are not damaged.
Old 10-18-2004, 03:17 PM
1PhatCX's Avatar
god dammit!
stupid fuckin plug wire came off the cap! timing belt was fine, god damnit. i put a new cap and rotor on lastnight and i guess the ends fit the old cap better then this one . just had to open them a bit and put em back in... works a hell of a lot better now
