Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-17-2004, 11:14 PM
RADMANX RADMANX is offline
B&M short shifter
How easy of an install is this?? and where is the cheapest place i could find one besides ebay becuase i have been ripped off too many times.
Like i always say, "I live my life a 1/4 mile at a time, and for those 19 seconds or more, i wish i was boosted..."
2000 Honda Civic EX
Just starting...
Old 10-18-2004, 05:08 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: B&M short shifter
should be an easy install. hardest part will be making sure your shiter is aligned right. somewhere on here somebody did a writeup one the easiest way to set it. i cant help you on a 2g.
you can get your stock one shortened if you know someone good with a torch. as for finding one check your local car places and if they dont have it see if they can special order one for you.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-18-2004, 06:08 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Ebay would be the cheapest, otherwise search google for random stores.
Instructions:
http://www.bmracing.com/products/shf...9500661-07.pdf
For Sale 98 Eclipse GS, 5 spd
Old 10-19-2004, 02:01 AM
tynebeach tynebeach is offline
Send a message via AIM to tynebeach
Try searching Vfaq.com . just look under DSM and then tips for shifters. They explain how to shorten the stock shifter if you have the right tools and it'll save you a couple bucks
91 Eagle Talon: Exhaust, ported turbo/mani/o2 housing, 15 psi, short route FMIC, etc..
96 Toyota Corolla: DD
Old 10-19-2004, 05:34 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
i bought a cheapy short throw shifter off ebay for my 96 gs. Took about 30 minutes to install. Fit right in and has worked great since. Have gone probally 5k miles with it installed with no problems.
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 10-19-2004, 12:54 PM
duckydsp's Avatar
duckydsp duckydsp is offline
http://store.racerwheel.org/handling...se-b-m-co.html
http://www.nopionline.com/nopistore/...Eclipse%201998
http://www.jcwhitney.com/autoparts/E...003320/c-10101
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 10-22-2004, 04:58 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Here are installation instructions from B&M:
http://www.roadraceengineering.com/i...structions.htm
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-22-2004, 07:49 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i put mine in myself in about an hour taking my time.
it is a great mod, but it is 100% better with the metal bushings
