Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-17-2004, 09:11 PM
doltmann doltmann is offline
Exclamation 1st Gen Start Problem!
Ok... pheww... Had problems starting, had tickets, had to take care of tickets, moved, moved again, got back, took care of tickets, trying to take care of 85 RX-7. All in the span of one year.
So, the car hasnt ran in a year, it stopped running and didnt have time to fix it... when i decided to get back to it... turned the key, nothing, absolutly nothing, decided i probably needed a new batt. replaced batt. turned key, nothing... replaced starter, turned key, nothing... noticed there was NO clutch fluid, filled and bled, clutch works!! YEA!!, tried starting it, nothing.. Cleaned all leads and ends, check fuses, checked clutch start intruppter, cranking voltage, all to no avail... im now at the point where when u turn the key, the starter clicks and the batt dropps to 8 volts and then you have nothing... until the batt starts fizziling because you forgot to let go of the key as you cussed the car. so... in general, it acts as if it has a dead batt... but it has a new one. ooh, and when we tried starting it without the clutched compressed, it TRIED to turn over, spun the fan about half a turn, made some WEIRD noises, and then stopped... and went back to its normal state.
So, any suggestions?
Old 10-17-2004, 10:41 PM
fcdriver fcdriver is offline
Re: 1st Gen Start Problem!
Will the engine turn over at all, like if you try turning it with a braker bar and socket onthe main pulley? If it will turn then have you checked the starter seloniod to see if it is allowing voltage to the starter?
Old 10-17-2004, 10:45 PM
no, ill try that next time that i get a chance.
any other suggestions if that doesnt work?
Old 10-17-2004, 10:51 PM
If that doesn't work and the engine will turn you might want to check the grounds maybe even go as far as to remove the starter and seeing if it will turn at all if it does then you may need to check the starter wires again just to be sure you are getting voltage to the starter.
Old 10-22-2004, 11:15 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
make sure you can turn the engine by hand, if it makes some weird noise, remove the sparkplugs and pour some ATF or mineral engine oil in the rotor chambers..
Old 10-23-2004, 11:58 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Do the headlights work?
Damn, thats the worst...
RX-7 TII
Old 10-23-2004, 09:17 PM
D3rELiC's Avatar
carbon lock is a normal thing.. it wont destroy the engine to do it once.
Old 10-24-2004, 10:29 PM
Sorry, i havent replied yet, i havent got a chance to work on it yet, keep on sendin in the advice!
Old 10-25-2004, 08:42 AM
Great-King-Rat Great-King-Rat is offline
Send a message via MSN to Great-King-Rat
If you can ever find the time...press the gas 4 or 5 times to the floor without tryint to start the car. Immediately after locate the fuel pump and youll notice a wire coming to the pump and one leaving. If possible, carefully pull the leaving wire apart from the pump. If no gas pours out, try replacing the fuel pump.
Old 10-25-2004, 08:52 AM
