Old 10-17-2004, 08:48 PM
aefd124 aefd124 is offline
1998 chevy lumini wont start
my 98 chevy lumina wont start. it doesnt start at all not evan a noise. i can how ever start it at the starter but it only runs for 5 seconds but then quits. I NEED HELP. by the way all the electrical stuff does turn on.
Old 10-17-2004, 09:49 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 1998 chevy lumini wont start
is the security light lit when you turn your ignition on, and try to start it?
Old 07-03-2005, 04:42 PM
noctorum noctorum is offline
Re: Re: 1998 chevy lumini wont start
Highjacking this a bit.
I have the same problem, and the security light comes on. How can I fix this?
Old 07-03-2005, 10:37 PM
bstrom1953 bstrom1953 is offline
Re: Re: Re: 1998 chevy lumini wont start
Do these cars have the anti-theft module with the "special chip" built into the key?
Do you have another key that is newer and in better condition? Try it.
My 95 Lumina would periodically refuse to crank over. I could crank it over by jumping the starter solenoid like aefd124. It would start and run for a few seconds but then stop. I traced the starting circuit to the anti-theft module...it was not allowing current to the starter solenoid. I looked at my key and saw the "chip" contacts were worn down a lot...so much that they were not making contact inside the ignition switch. I changed over to a newer key and the car started immediately!
I took the old key and built up the contacts with a little solder and now it works fine.
By the way, my Security Light came on at odd times like noctorum. That was because of the worn out key. The computer thought I had the wrong key or no key at all.
