Old 10-17-2004, 08:40 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
hydraulic clutch
my car has a hydraulic cluch and the fluid level is in the "LOW" mark i know it uses brake fluid but dont know if i should use DOT 3 or DOT 4, and what if i have DOT 3 and i add DOT 4 or if it has DOT 4 and i add DOT 3 will it mess it up or will it work. cuz i dont know which one it has.
(it looks gray)
thanks
my cardomain
Old 10-17-2004, 09:05 PM
public's Avatar
public public is offline
Re: hydraulic clutch
I should say on the cap. Usually DOT 3. DOT 4 is more heat resistant. As for mixing ??????????
Someone here will know about that I am sure.
Old 10-18-2004, 12:30 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
DOT3 and DOT4 are interchangible, but not mixible. IE if you had DOT3 in your system, and wanted to use DOT4, you would need to flush the system. DOT5 in not compatable with ether. if the fuild is low, you ether have a leak in the system or the clutch is worn down and will need replaced soon.
check the owners manual if its not on the cap.
Old 10-18-2004, 10:06 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Top it off, it should say on the cap what DOT number it is. Keep an eye on it, and if you have to add to it too frequently, get it checked out.
