Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 10-17-2004, 07:11 PM
cbbond cbbond is offline
Front-end Troubles ('58 Beetle)
To Whom It May Concern:
I have problematic front-end in my '58 vw beetle. Symptoms:
(1) Too much play in steering wheel (especially when hitting bumps in the road); (2) The high winds will push my beetle all over the road; (3 related to #1) Beetle is hard to control when road is rough...
It appears that there are some worn out components in my front-end. Someone mentioned that I need work done on the 'king-pins'. Others say that I have worn out ball joints, but I don't think that my model has ball joints. What kind of parts and or repair do I need to correct this problem.
Any words of wisdom out there on this topic?
Thanks,
Casey
Old 10-18-2004, 04:45 PM
boschmann boschmann is offline
Re: Front-end Troubles ('58 Beetle)
You are correct it doesn't have ball joints, just king & link pins. You can jack the car by the frame & rock each wheel by grabbing it at the top & bottom. Look at the pins to see if the play is there. If it something you want to try yourself get a good manual like Bentley. You might also want to see if the rubber disc between the steering box & steering shaft is intact. There could also be play in the box itself.
