Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-17-2004, 05:51 PM
sniper_06 sniper_06 is offline
Turbo not making boost
I am buying a 1989 dodge daytona shelby with the turbo 2 engine. the car is fine except that turbo isnt making full boost, it used to go to 14-5 psi. My friend owns it now and he said that it just didnt make boost one day and its been like that since. I read on a web page that it just might be a bad wastegate. The turbo was fully taken apart inspected and cleaned last summer by a dodge dealer.
Any help would be nice
thanks
Old 10-17-2004, 05:56 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Turbo not making boost
yes it is probably a waste gate stuck open or a leaking BOV.
Old 10-17-2004, 09:56 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
well, that car didn't come with a BOV, so it can't be that.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-17-2004, 11:04 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
You're right, the Turbo II doesn't have a BOV. Also, the most the Turbo II can make stock is 14.7 PSI. After that the stock injectors can't keep up. Now to help you out I need to know a couple of things. How much is your max boost right now? Also, does it hit the boost cutout?
The first place I would check is the wastegate.
Old 10-18-2004, 05:16 PM
Talking
Well now for some reason the turbo is making full boost, 14 psi. so i think the gauge was off or somthing, btu no there is a different problem the pop up head lights are not coming up. The dash lights are coming on but no headlights, any help would be appreciated.
Old 10-18-2004, 05:18 PM
And actually there is a BOV but dodge does not call it that, it is set up to blow the air right into the air box.
Old 10-18-2004, 08:05 PM
CBFryman's Avatar
Banned
i didnt know if it did or not, but that was the problem on a friends turbo eclipse. he upgraded the turbo and wastegate and ran 5-6psi above stock but used the stock BOV and you would hear the BOV start kicking in before the turbo was compltely spooled....and normally BOV's dont even blow off untill the throttle body is snaped shut.
Old 10-18-2004, 08:22 PM
yeah it says it has a bov but there isnt th typical woosh you know, but does anyone have any idea about the head lights
Old 10-18-2004, 10:16 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
I'm thinkin' something along the lines of an electrical problem.
And in an earlier post, when it was said that the Turbo 2 didn't come with a BOV, I just about dropped a brick in my pants. A DV maybe, like in most other cars (even your Eclipse).
Here's my understanding of the difference between BOVs and DVs:
-DVs vent back to the intake pre-turbo.
-BOVs vent to atmosphere.
Old 10-19-2004, 09:40 AM
Polygon's Avatar
The Red Baron
Re: Re: Turbo not making boost
Bingo!
A blow off valve and a diverter valve are two types of shift valves. The DSMs and the Turbo II both use diverter valves. As for the headlights, do the headlights come on, but they simply don't pop up, or they don't come on at all and don't pop up?
So you are making full boost now? What was wrong?
Old 10-22-2004, 09:56 AM
Ok i bought the car and it had full boost back, the guy i bought it from had stored it for about a year and when he put it away he said it only made 5 psi and when we brought it out so i could buy it it worked fine, i brought it to a shop where i used to work at(midwest performance) and he told me the waste gate actuator was probably stuck and just let loose over time. but about the head lights, i am ust bye passing the whole system and i am goign to run off a switch.
Old 10-22-2004, 09:58 AM
Well one more little problem that i noticed today, it seems like the car drops off power afer 4500 rpms and it cuts out at 5000--that is really confusing cause max powere is supposed to be 174 horse at 6000 so??????????
Old 10-26-2004, 10:47 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
How many miles does this car have on it? When was the turbo last rebuilt? Engine rebuilt? Fuel system gone over? Ignition? Any of these can cause your engine to loose power.
Old 10-27-2004, 03:11 PM
the car has 133000 miles, engine has never been rebuilt. The turbo was totally cleaned and inspected last summer.
