Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-17-2004, 04:39 PM
BrianEclipse BrianEclipse is offline
code 1390
my car was running great but was time to change my timing belt so we did. now at low rpms and idle its missing it seems. check engine light came on. is that normal? like is the computer tring to adjust to the new belt?
99 gs nt. please help
Old 10-17-2004, 05:33 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: code 1390
No that is not normal. The code is saying that the timing belt skipped a tooth or more. So go back and check everthing out.
For Sale 98 Eclipse GS, 5 spd
Old 10-17-2004, 05:48 PM
ok thanks alot. you are the man once again. i think he tried to rush it. anything i should suggest to him about best way to get it right the second time? lol thanks again
Old 10-17-2004, 06:19 PM
ashah000's Avatar
Re: code 1390
If you haven't looked at the vfaq for changing the timing belt? If not, take a look at that.
From 2gnt's ecu code page:
Check timing belt / Check crankshaft sensor and camshaft position sensor / Check PCM connector
