My 94 Sable over heats every time I drive...I replaced the radiator and put in new thermostat.. I have a feeling that the fan is not coming on any help on this would be great!! any thing I should know????
Re: Car O/Heating NEED HELP!!!
If you suspect the fan isn't coming on, I would start by checking the electrical system. Check fuses, then check for loose wires from fan to fuse. If you don't find any problems there, you can disconnect the wires to the fan and test the fan itself straight from the battery with some jumper wires. Good luck!
there are two different sensors to replace one is for the tempature sensor for radiator and the other is for the computer they are both located by the thermastat when i changed those my fan kicked right on also you might wanna check the relay module for that car
over heat
two things. are you losing coolant?
these cars are bad for head gaskets that can cause an over heat the fan problem on my 94 sable was a bad ground close to the battery, as was said directly powering the fan can save a lot of time, if ok then check down the line for wiring, switches and fuses. the fan is also controled by mutiple relays MB |
